Epson Stylus SX515W A4 AIO - 36ppm 1200dpi
Epson SX 510W Series Printer
Quicklinx: 5K4SWS00 Mfr#: C11CA48311
Enjoy wireless access to this fast, high quality all-in-one and make printing and scanning even easier. With the large 6.3 cm LCD viewer you can also view, select and print your photos straight from your digital camera´s memory card without the need to switch on your PC.
Whether you print photos or make quick copies of documents, Epson DURABrite Ultra Ink gives you superb prints that are resistant to water, fading and even highlighter pens. And with individual inks you only need to replace the color used, which saves you money too.
Epson Stylus SX515W - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 36 ppm (mono) / up to 36 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
2400 x 2400 dpi
Display
2.5"
Original Size
216 x 297 mm (max)
Media Size
216 x 356 mm (max)
Media Type
Plain paper, photo paper
Standard Media Capacity
120 sheets
Connection Availability
USB 2.0, LAN, USB host, Wi-Fi
Office Machine Features
Print from memory card, print from USB flash drive
AC 230 V (50/60Hz)
45 cm x 34.2 cm x 18.2 cm
6.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.5"
Supported Flash Memory
Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO, USB flash drive, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
2400 x 2400 dpi
Document & Media Handling
Max Original Size
216 x 297 mm
Max Media Size
Other
Supported Media Type
120 sheets
Speed Details
Printing: up to 36 ppm (A4) - B/W , Printing: up to 36 ppm (A4) - colour , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows 2000, Apple Mac OS X 10.3.9, MS Windows Vista, MS Windows XP 64-bit Edition
Software Included
Epson Event Manager, EPSON Web-to-Page, ABBYY FineReader 5.0 Sprint Plus, ABBYY FineReader 6.0 Sprint Plus, Epson Easy Photo Print
AC 230 V (50/60Hz)
Direct Printing Specifications
PictBridge
USB cable
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black)
ENERGY STAR Certified
Limited warranty - 1 year
45 cm
34.2 cm
18.2 cm
6.1 kg
Sound Emission
5.5 dBA (idle) / 42.5 dBA (operating)
5K4S Epson T071 Black Ink Cartridge In Stock £17.60
Resources
The following resources are available for the Epson Stylus SX515W A4 AIO - 36ppm 1200dpi
