Epson Stylus SX435W - multifunction ( copier / printer / scanner ) ( colour )
Epson Small-in-One
Quicklinx: 7Q4TWS00 Mfr#: C11CB21304
The Epson Stylus SX435W is part of the Small-in-One range - Epson's smallest all-in-ones which are 39 percent smaller than previous models. This model offers cost-effective printing for home users who are looking for the added benefit of Wi-Fi connectivity and PC-free printing.
The new design coupled with an ultra-compact footprint means this Small-in-One complements any modern home environment without taking up too much space.
Individual DURABrite Ultra Ink cartridges save users money as they only replace the colours used. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents.
The automatic Wi-Fi set-up makes configuring laptops and computers to print wirelessly extremely easy. Users don't need to know their network settings or connect with a USB cable, the SX435W automatically finds the relevant connection settings in order to configure itself.
With a 3.6cm colour LCD screen and accompanying memory card slot, this all-in-one offers easy-to-use PC-free photo printing with its helpful menu prompts. No more waiting for computers to power up; printing directly from a memory card is straightforward and allows greater flexibility.
The SX435W also comes with Epson Connect which offers even more flexibility and freedom, allowing users to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs (Requires Epson printing app).
Thanks to its ultra-compact size, this Small-in-One boasts a 25 percent reduction in packaging which means home users throw away less, helping lower their impact on the environment.
In the box:
- Epson Stylus SX435W printer
- Four individual ink cartridges
- Software CD
- `Start Here' guide
- User Guide
- Warranty document
- Power cable
  • Save space
    The SX435W is part of the Small-in-One range - Epson's smallest all-in-ones which are 39 percent smaller than previous models. The sleek, stylish design coupled with an ultra-compact footprint means this Small-in-One effortlessly complements any home environment without taking up too much space. Additionally, this Small-in-One boasts a 25 percent reduction in packaging, which means you throw away less and helps lower your impact on the environment.
  • Save money
    By using four individual ink cartridges you only replace the color used, making this an all-round, affordable device. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents.
  • Save time
    The automatic Wi-Fi set-up makes configuring laptops and computers to print wirelessly extremely easy. You don't need to know your network settings or connect with a USB cable, the SX435W automatically finds the relevant connection settings in order to configure itself. Multiple users then have the freedom to print, copy and scan quickly and efficiently from anywhere in the home.
  • PC-free printing
    The 3.6cm color LCD screen and accompanying memory card slot offers easy-to-use PC-free photo printing with helpful menu prompts, meaning no more waiting for computers to power up; printing directly from a memory card allows greater flexibility and is straightforward.
  • Mobile printing
    The SX435W is also compatible with Epson iPrint which offers even more flexibility and freedom, allowing you to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs.
Copier Type
Digital
39 cm x 30 cm x 14.5 cm
4.1 kg
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 33 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1400 dpi (mono) / up to 5760 x 1400 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
PC Connection
Hi-Speed USB, IEEE 802.11b, IEEE 802.11g
Office Machine Features
Print from memory card
AC 110/230 V
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax / copier / printer / scanner
Copier Type
Digital
Printing Technology
Ink-jet - colour
39 cm
30 cm
14.5 cm
4.1 kg
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, miniSD, Memory Stick PRO, Memory Stick Duo, miniSDHC, MicroSDHC, Memory Stick Micro (M2), MultiMediaCardplus, Memory Stick PRO Duo, MicroSD, SDHC Memory Card, RS-MMC
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
128 nozzles (black), 3 x 42 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Copy Size
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, C6 (114 x 162 mm), 200 x 250 mm, 130 x 200 mm
100 sheets
Speed Details
Printing : up to 33 ppm ( A4 ) - B/W , Printing : up to 15 ppm ( A4 ) - colour , Printing : 54 sec ( 10 x 15 cm (4"x6") ) - photo
PC Connectivity
PC Connection
Security Protocols & Features
WEP, WPA-PSK, WPA2, TKIP, AES
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for Mac
AC 110/230 V
15 Watt
Power Consumption Sleep
3 Watt
Consumables Included
1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow ) , 1 x Cartridge ( black )
1 year warranty
Service & Support Details
Limited warranty - 1 year
Sound Emission
5.2 dBA (idle) / 38 dBA (operating)
7Q4T Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.58
7Q4T Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.93
7Q4T Epson A4 Iron On Transfer Pack 10sht In Stock £14.64
Resources
The following resources are available for the Epson Stylus SX435W - multifunction ( copier / printer / scanner ) ( colour )
