The Epson Stylus SX435W is part of the Small-in-One range - Epson's smallest all-in-ones which are 39 percent smaller than previous models. This model offers cost-effective printing for home users who are looking for the added benefit of Wi-Fi connectivity and PC-free printing.
The new design coupled with an ultra-compact footprint means this Small-in-One complements any modern home environment without taking up too much space.
Individual DURABrite Ultra Ink cartridges save users money as they only replace the colours used. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents.
The automatic Wi-Fi set-up makes configuring laptops and computers to print wirelessly extremely easy. Users don't need to know their network settings or connect with a USB cable, the SX435W automatically finds the relevant connection settings in order to configure itself.
With a 3.6cm colour LCD screen and accompanying memory card slot, this all-in-one offers easy-to-use PC-free photo printing with its helpful menu prompts. No more waiting for computers to power up; printing directly from a memory card is straightforward and allows greater flexibility.
The SX435W also comes with Epson Connect which offers even more flexibility and freedom, allowing users to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs (Requires Epson printing app).
Thanks to its ultra-compact size, this Small-in-One boasts a 25 percent reduction in packaging which means home users throw away less, helping lower their impact on the environment.
In the box:
- Epson Stylus SX435W printer
- Four individual ink cartridges
- Software CD
- `Start Here' guide
- User Guide
- Warranty document
- Power cable
Save space
The SX435W is part of the Small-in-One range - Epson's smallest all-in-ones which are 39 percent smaller than previous models. The sleek, stylish design coupled with an ultra-compact footprint means this Small-in-One effortlessly complements any home environment without taking up too much space. Additionally, this Small-in-One boasts a 25 percent reduction in packaging, which means you throw away less and helps lower your impact on the environment. -
Save money
By using four individual ink cartridges you only replace the color used, making this an all-round, affordable device. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents. -
Save time
The automatic Wi-Fi set-up makes configuring laptops and computers to print wirelessly extremely easy. You don't need to know your network settings or connect with a USB cable, the SX435W automatically finds the relevant connection settings in order to configure itself. Multiple users then have the freedom to print, copy and scan quickly and efficiently from anywhere in the home. -
PC-free printing
The 3.6cm color LCD screen and accompanying memory card slot offers easy-to-use PC-free photo printing with helpful menu prompts, meaning no more waiting for computers to power up; printing directly from a memory card allows greater flexibility and is straightforward. -
Mobile printing
The SX435W is also compatible with Epson iPrint which offers even more flexibility and freedom, allowing you to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs.
- Copier Type
- Digital
- 39 cm x 30 cm x 14.5 cm
- 4.1 kg
- Printing Technology
- Ink-jet ( colour )
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 33 ppm (mono) / up to 15 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1400 dpi (mono) / up to 5760 x 1400 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- PC Connection
- Hi-Speed USB, IEEE 802.11b, IEEE 802.11g
- Office Machine Features
- Print from memory card
- Power
- AC 110/230 V
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1 year warranty
- Fax / copier / printer / scanner
- Copier Type
- Digital
- Ink-jet - colour
- 39 cm
- 30 cm
- 14.5 cm
- 4.1 kg
- Supported Flash Memory
- Memory Stick, SD Memory Card, MultiMediaCard, miniSD, Memory Stick PRO, Memory Stick Duo, miniSDHC, MicroSDHC, Memory Stick Micro (M2), MultiMediaCardplus, Memory Stick PRO Duo, MicroSD, SDHC Memory Card, RS-MMC
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 128 nozzles (black), 3 x 42 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3 pl
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- Max Copy Size
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, C6 (114 x 162 mm), 200 x 250 mm, 130 x 200 mm
- 100 sheets
- Speed Details
- Printing : up to 33 ppm ( A4 ) - B/W , Printing : up to 15 ppm ( A4 ) - colour , Printing : 54 sec ( 10 x 15 cm (4"x6") ) - photo
PC Connectivity
- PC Connection
- WEP, WPA-PSK, WPA2, TKIP, AES
- Operating System Support
- MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
- Software Included
- Epson Event Manager, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for Mac
- Voltage Required
- AC 110/230 V
- 15 Watt
- Power Consumption Sleep
- 3 Watt
- Consumables Included
- 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow ) , 1 x Cartridge ( black )
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
- Sound Emission
- 5.2 dBA (idle) / 38 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £16.39 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.79 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £14.48 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.79 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.23 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £15.23 |
