Epson Stylus SX218 Multifunction Printer/Copier/Scanner
Epson Stylus SX218 Printer
Quicklinx: 75FRWS00 Mfr#: C11CA81301
This fuss-free all-in-one has a colour LCD and memory card slots for fast, easy photo printing without a PC. It also saves you money with individual ink cartridges.
This all-in-one printer, scanner and copier has an LCD screen and memory card slots for effortless, lab-quality photo printing without the need for a PC.
Produce outstanding documents and lab-quality photos that last longer with water, fade, smudge and highlighter-resistant Epson DURABrite Ultra Ink. And individual ink cartridges save you money too as you only replace the colour used.
You can remove red-eye, adjust colour and restore and enhance photos at the touch of a button with Epson Easy Photo Print and Epson PhotoEnhance, and even scan text into editable documents with ABBYY FineReader® OCR software.
  • Photo processing
    Remove red eye from photos, restore colour and correct backlight with our Easy Photo Fix function and Easy Photo Print software. When you're happy with the image, you can print up to A4 borderless photos.
  • Incredible, long-lasting colours
    DURABrite Ultra Inks deliver fast-drying prints that resist water, highlighter pens, smudging and fading so your lab-quality photos will last for generations to come.
  • Save money
    By using four individual ink cartridges you only replace the colour used, making this an all-round, affordable device.
  • Hassle-free
    Print, scan and copy with this simple, straightforward, all-in-one. Includes ABBYY FineReader OCR software for easy scanning of documents into text for editing. Ideal for making light work of scanning reports, recipes and materials for college assignments.
Epson Stylus SX218 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 34 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Display
1.5"
Original Size
A4 (210 x 297 mm) (max)
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
120 sheets
Connection Availability
USB 2.0
AC 230 V
45 cm x 34.2 cm x 18.2 cm
5.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.5"
USB 2.0
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
90 nozzles (black), 29 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
4 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
120 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W , Printing: up to 15 ppm (A4) - colour , Printing: 72 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
Software Included
Epson Event Manager, EPSON Scan, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for Mac
AC 230 V
13 Watt
Power Consumption Sleep
2.5 Watt
Consumables Included
1 x ink cartridge (black) ¦ 1 x ink cartridge (cyan) ¦ 1 x ink cartridge (magenta) ¦ 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
45 cm
34.2 cm
18.2 cm
5.7 kg
Sound Emission
40 dBA (operating)
75FR Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.59
75FR Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.94
75FR Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.94
