Affordable All-in-One
This printer, scanner and copier is the ideal choice for home users and students who need a compact all-in-one that can print, copy and scan at an affordable price.
Epson's Stylus SX130 is the complete package that helps users with a selection of tasks, from printing coursework and photos to scanning and copying important documents. The SX130 is great value for money, ideal for users who want to spend their budget wisely.
Individual inks offer up to a 34 percent ink saving, compared to competitors' combined ink cartridges. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents. Because of its durability, prints are highlighter, water, smudge, and fade resistant ensuring long-lasting prints.
With its compact dimensions, the SX130 is able to neatly fit in any home environment without taking up too much space thanks to its smaller footprint.
Value-for-money: Individual inks offer users up to a 34 percent ink saving, compared to competitors' combined ink cartridges. Never waste colours either, as you only replace the colour used.
User-friendly: Ideal for users who want to perform tasks quickly and with the minimum of fuss. The four-button control panel makes this all-in-one easy to use and straightforward to set up.
Space-saving: With its compact dimensions, the SX130 is able to neatly fit in any home and effortlessly complements a variety of environments with its stylish design.
Economical
Save money with individual inks
Versatile
Print documents and photos
User-friendly
Four-button control panel
Space-saving
Compact all-in-one
Power efficient
ENERGY STAR-qualified
Economical
Save money with individual inks. -
Versatile
Print documents and photos. -
User-friendly
Four-button control panel. -
Space-saving
Compact all-in-one. -
Power efficient
ENERGY STAR-qualified.
- Epson Stylus SX130 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 28 ppm (mono) / up to 15 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 600 x 1200 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Connection Availability
- Interface
- USB
- Power
- AC 230 V
- 43.6 cm x 30.4 cm x 15 cm
- 3.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- Interface
- USB
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 90 nozzles (black), 29 nozzles (per colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 4 pl
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- Max Media Size
- Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- 100 sheets
- Speed Details
- Printing: up to 28 ppm (A4) - B/W , Printing: up to 15 ppm (A4) - colour , Printing: 93 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB
- Operating System Support
- MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.4.11 or later
- Software Included
- Epson Event Manager, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac
- Voltage Required
- AC 230 V
- 12 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Limited warranty - 1 year
- 43.6 cm
- 30.4 cm
- 15 cm
- 3.9 kg
- Sound Emission
- 37.6 dBA (operating)
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.90 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.38 |
