Epson Stylus SX130 (printer/scanner/copier)
Epson Small-in-One
Quicklinx: 7JSYWS00 Mfr#: C11CB54301
Affordable All-in-One
This printer, scanner and copier is the ideal choice for home users and students who need a compact all-in-one that can print, copy and scan at an affordable price.
Epson's Stylus SX130 is the complete package that helps users with a selection of tasks, from printing coursework and photos to scanning and copying important documents. The SX130 is great value for money, ideal for users who want to spend their budget wisely.
Individual inks offer up to a 34 percent ink saving, compared to competitors' combined ink cartridges. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents. Because of its durability, prints are highlighter, water, smudge, and fade resistant ensuring long-lasting prints.
With its compact dimensions, the SX130 is able to neatly fit in any home environment without taking up too much space thanks to its smaller footprint.
Value-for-money: Individual inks offer users up to a 34 percent ink saving, compared to competitors' combined ink cartridges. Never waste colours either, as you only replace the colour used.
User-friendly: Ideal for users who want to perform tasks quickly and with the minimum of fuss. The four-button control panel makes this all-in-one easy to use and straightforward to set up.
Space-saving: With its compact dimensions, the SX130 is able to neatly fit in any home and effortlessly complements a variety of environments with its stylish design.
Economical
Save money with individual inks
Versatile
Print documents and photos
User-friendly
Four-button control panel
Space-saving
Compact all-in-one
Power efficient
ENERGY STAR-qualified
  • Economical
    Save money with individual inks.
  • Versatile
    Print documents and photos.
  • User-friendly
    Four-button control panel.
  • Space-saving
    Compact all-in-one.
  • Power efficient
    ENERGY STAR-qualified.
Epson Stylus SX130 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 28 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB
AC 230 V
43.6 cm x 30.4 cm x 15 cm
3.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
USB
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
90 nozzles (black), 29 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
4 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
100 sheets
Speed Details
Printing: up to 28 ppm (A4) - B/W , Printing: up to 15 ppm (A4) - colour , Printing: 93 sec (10 x 15 cm (4"x6")) - photo
1 x USB
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.4.11 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac
AC 230 V
12 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year
43.6 cm
30.4 cm
15 cm
3.9 kg
Sound Emission
37.6 dBA (operating)
7JSY Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.79
7JSY Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.79
7JSY Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.23
