Epson Stylus S22 - printer - colour - ink-jet
Quicklinx: 76GPWS00 Mfr#: C11CA83301
This no-nonsense printer is perfect for all your home documents and photos and saves you money with individual ink cartridges. This reliable, economical printer makes home photo and document printing simple and effortless. Prints look great and last longer on any paper because Epson DURABrite Ultra ink is water, smudge, fade and even highlighter resistant. You can remove red-eye and adjust colour and contrast in a fl ash with the included software to ensure your photos always look their best. Individual ink cartridges save you money as you only replace the colour used, and this power-efficient ENERGY STAR® qualified printer will also help to reduce your energy bills and environmental impact.
Key Benefits
- Individual ink cartridges: - Save money by only replacing the colour used
- Epson DURABrite Ultra Ink: - Produce high-quality documents with our high-quality ink
- Epson PhotoEnhance: - Automatically adjusts colour and contrast for perfect results
- Remove red eye: - Epson Easy Photo Print removes red eye from your images
- Up to 5760x1440 optimised dpi - on suitable media using RPM (Resolution Performance Management)
- Clean design: - Smart and discreet, will easily slot into any space
Box Contents
- 4 individual ink cartridges
- Software CD
- 'Start Here' guide
- Warranty document
- Power cable
Printer Type
Personal printer - ink-jet - colour
2.4 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 28 ppm - B/W - A4 (210 x 297 mm) , Up to 15 ppm - colour - A4 (210 x 297 mm) , Up to 1.48 min/page - photo - 100 x 150 mm
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
Image Enhancement Technology
EPSON Variable-sized Droplet Technology
USB
Media Type
Envelopes, plain paper, photo paper
Total Media Capacity
100 sheets
Media Handling
100-sheet input tray
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Apple MacOS X 10.3.9, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later
Microsoft Certification
Works with Windows Vista
1-year warranty
41.5 mm x 22.7 cm x 13.5 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
90 nozzles (black), 29 nozzles (per colour)
Minimum Ink Droplet Size
4 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Wired
USB
5760 x 1440 dpi
5760 x 1440 dpi
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
1 x USB - 4 pin USB Type B
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
10.1 Watt
Power Consumption Stand by / Sleep
1.2 Watt
Software Included
EPSON Web-to-Page, EPSON Easy Photo Print
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Operating)
42 dBA
41.5 mm
22.7 cm
13.5 cm
2.4 kg
76GP Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.29
76GP Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.72
76GP Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.79
