This no-nonsense printer is perfect for all your home documents and photos and saves you money with individual ink cartridges. This reliable, economical printer makes home photo and document printing simple and effortless. Prints look great and last longer on any paper because Epson DURABrite Ultra ink is water, smudge, fade and even highlighter resistant. You can remove red-eye and adjust colour and contrast in a fl ash with the included software to ensure your photos always look their best. Individual ink cartridges save you money as you only replace the colour used, and this power-efficient ENERGY STAR® qualified printer will also help to reduce your energy bills and environmental impact.
Key Benefits
- Individual ink cartridges: - Save money by only replacing the colour used
- Epson DURABrite Ultra Ink: - Produce high-quality documents with our high-quality ink
- Epson PhotoEnhance: - Automatically adjusts colour and contrast for perfect results
- Remove red eye: - Epson Easy Photo Print removes red eye from your images
- Up to 5760x1440 optimised dpi - on suitable media using RPM (Resolution Performance Management)
- Clean design: - Smart and discreet, will easily slot into any space
Box Contents
- 4 individual ink cartridges
- Software CD
- 'Start Here' guide
- Warranty document
- Power cable
- Epson Stylus S22 - printer - colour - ink-jet
- Printer Type
- Personal printer - ink-jet - colour
- 2.4 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 28 ppm - B/W - A4 (210 x 297 mm) , Up to 15 ppm - colour - A4 (210 x 297 mm) , Up to 1.48 min/page - photo - 100 x 150 mm
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Image Enhancement Technology
- EPSON Variable-sized Droplet Technology
- Interface
- USB
- Media Type
- Envelopes, plain paper, photo paper
- Total Media Capacity
- 100 sheets
- Media Handling
- 100-sheet input tray
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Apple MacOS X 10.3.9, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 41.5 mm x 22.7 cm x 13.5 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 90 nozzles (black), 29 nozzles (per colour)
- Minimum Ink Droplet Size
- 4 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 5760 x 1440 dpi
- 5760 x 1440 dpi
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Connections
- 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- 10.1 Watt
- Power Consumption Stand by / Sleep
- 1.2 Watt
- Software Included
- EPSON Web-to-Page, EPSON Easy Photo Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Operating)
- 42 dBA
- 41.5 mm
- 22.7 cm
- 13.5 cm
- 2.4 kg
