Epson Stylus Pro 9700 44" High Speed Large Format Printer
Epson Stylus Pro 7700/9700 Printer
Quicklinx: 761XWS00 Mfr#: C11CA59001A0
Precision, reliability and productivity; meeting a wide range of professional printing needs.
Professional printers designed to provide faster output without compromising on print quality.
Flawless colour
The Epson Stylus Pro 9700 flexible 44" printer gives your professional printing even more impact with thea ddition of Vivid Magenta to the Epson UltraChrome Ink set. With more accurate, longer-lasting, life-like colour it will transform the way you print POS materials, CAD/GIS prints and more.
Fast, efficient printing
The Epson Stylus Pro 9700 is packed with the latest Epson technologies that add precision, reliability and productivity to a wide range of professional printing needs. Together they give you the finest quality output without compromising speed.
Simple excellence
A range of features make the printing process as easy as possible, and gives you the flexibility to match your printer to the way you print. Fast network connection, clear, simple control and straightforward operation and maintenance are built-in.
Total control
Intelligent software helps you to get the best from your printer; whether it's keeping track of all aspects of printing, streamlining the way you work or getting creative.
Meeting demands
From business to education, our versatile printer gives you high-quality, eye-catching prints that do the job perfectly. With industry-standard quality, accuracy and durability, it combines all the features you need to transform the way your business works.
  • Flawless colour
    Our fast, flexible 44" printer gives your professional printing even more impact with the.
  • Fast, efficient printing
    The Epson Stylus Pro 9700 is packed with the latest Epson technologies that add precision.
  • Simple excellence
  • Total control
    Intelligent software helps you to get the best from your printer; whether it's keeping track of all aspects.
  • Meeting demands
Epson Stylus Pro 9700 - large-format printer - colour - ink-jet
Printer Type
44" large-format printer - ink-jet - colour
115 kg
Inkjet Technology
Epson Micro Piezo TFP
Ink Palette Supported (Colours)
4-ink
Max Media Size
B0 plus (1118 x 1580 mm), Roll (111.8 cm)
Max Resolution (B&W)
2880 x 1440 dpi
Max Resolution (Colour)
2880 x 1440 dpi
USB, LAN
Preview Screen Size
2.5"
Language Simulation
EPSON ESC/P 2, EPSON ESC/P Raster, EPSON ESC/P 3
Print server - Ethernet, Fast Ethernet
Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista (32/64 bits)
Microsoft Certification
Works with Windows Vista
1-year warranty (Poland - 2 years on-site)
186 cm x 66.7 cm x 121 cm
Printer Type
Printer
Inkjet Technology
4-ink
Nozzle Configuration
10 x 360 nozzles
Minimum Ink Droplet Size
3.5 pl
Ink Type
Epson UltraChrome
Built-in Devices
Preview screen
Preview Screen Size
2.5"
Wired
USB, LAN
2880 x 1440 dpi
2880 x 1440 dpi
Language Simulation
Media Handling
Max Media Size
Media Feeders
1 x manual - 1 roll - Roll (111.8 cm)
Print server
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Frequency Required
50/60 Hz
70 Watt
Power Consumption Stand by / Sleep
1 Watt
Limited warranty - 1 year - on-site
Regional Warranty Exceptions
10 °C
35 °C
20 - 80%
Sound Emission (Operating)
50 dBA
186 cm
66.7 cm
121 cm
115 kg
761X Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.72
761X Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.79
761X Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £20.59
761X Epson A3 Matte Paper Heavyweight 50 sheets In Stock £28.08
