Epson Stylus Pro 7900 24" Colour Inkjet Large Format Printer & SpectroProofer (non-UV)
Quicklinx: 5D9NWS00 Mfr#: C11CA12001A1
Ensure the highest quality for your fine art, photo printing and proofing with the Epson Stylus Pro 7900 24" printer. Delivering the widest color gamut available today, it uses UltraChrome HDR, an advanced 11-color ink set incorporating new orange and green inks. The result is a higher percentage of standard spot colors to be accurately reproduced, and maximum expression for photo and fine art applications.You'll benefit from high levels of productivity thanks to the Stylus Pro 7900's speed, ease of use and reliability. The TFP print head achieves top image quality, even at high print speeds up to 46M-¦/hr at resolutions up to 2880 dpi. Switching between photo and matte black inks is automatic.Managing and calibrating your color is easy with the in-line, off carriage SpectroProofer version powered by X-Rite. It provides advanced measurement and certification, and is fully automatic.
  • Epson PreciseColor manufacturing
    In order to ensure consistent printing between multiple Stylus Pro printers of the same model, Epson has refined the manufacturing process to include colorimetric calibration. Eliminating the need for internal calibration devices, this system evaluates and adjusts each printer's performance at the manufacturing stage, ensuring consistent color output from printer to printer and print to print.
  • Automatic black ink mode switching
    With both ink cartridges installed simultaneously, the Epson Stylus Pro series printers automatically utilize the optimal ink mode, delivering maximum density for the chosen media. Taking advantage of the Epson MicroPiezo TFP auto-sharing ink channel ensures a fast and efficient switch. And to further reduce switching errors, the user confirms the switching process from the front control panel.
Epson Stylus Pro 7900 - large-format printer - colour - ink-jet - with Epson SpectroProofer 24
Printer Type
24" large-format printer - ink-jet - colour
80 kg
Inkjet Technology
Epson Micro Piezo TFP
Ink Palette Supported (Colours)
10-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
Max Media Size
Roll A1 (61.0 cm)
Min Media Size (Custom)
203.2 mm
Max Media Size (Custom)
610 mm
Print Speed
Up to 40 sq.m/hour - draft
Max Resolution (B&W)
2880 x 1440 dpi
Max Resolution (Colour)
2880 x 1440 dpi
USB, LAN
Media Type
Plain paper, continuous forms
Print server - Ethernet, Fast Ethernet - internal
Printer Features
Borderless printing, EPSON Ultra Micro Dot
Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / 2000 / XP
Microsoft Certification
Compatible with Windows 7
1-year warranty (Poland - 2 years on-site)
136 cm x 66.7 cm x 121 cm
Bundled with
Printer Type
Bundled with
Printer
Inkjet Technology
Nozzle Configuration
10 x 360 nozzles
Minimum Ink Droplet Size
3.5 pl
Ink Cartridge Configuration
11 individual ink tanks
Ink Type
Epson UltraChrome HDR
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
2880 x 1440 dpi
2880 x 1440 dpi
Printer Features
Media Handling
Media Type
Max Media Size
Roll A1 (61.0 cm)
203.2 mm
610 mm
Media Sizes
Roll A1 (61.0 cm)
Media Thickness Range
Up to 1.5 mm
Media Feeders
1 x manual - 1 roll - Roll A1 (61.0 cm)
Print server - internal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (vivid light magenta) , 1 x ink cartridge (light black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (orange) , 1 x ink cartridge (green)
Power supply - internal
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
Regional Warranty Exceptions
136 cm
66.7 cm
121 cm
80 kg
5D9N Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.37
5D9N Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.78
5D9N Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.78
5D9N Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £20.69
Resources
The following resources are available for the Epson Stylus Pro 7900 24" Colour Inkjet Large Format Printer & SpectroProofer (non-UV)
