Ensure the highest quality for your fine art, photo printing and proofing with the Epson Stylus Pro 7900 24" printer. Delivering the widest color gamut available today, it uses UltraChrome HDR, an advanced 11-color ink set incorporating new orange and green inks. The result is a higher percentage of standard spot colors to be accurately reproduced, and maximum expression for photo and fine art applications.You'll benefit from high levels of productivity thanks to the Stylus Pro 7900's speed, ease of use and reliability. The TFP print head achieves top image quality, even at high print speeds up to 46M-¦/hr at resolutions up to 2880 dpi. Switching between photo and matte black inks is automatic.Managing and calibrating your color is easy with the in-line, off carriage SpectroProofer version powered by X-Rite. It provides advanced measurement and certification, and is fully automatic.
Epson PreciseColor manufacturing
In order to ensure consistent printing between multiple Stylus Pro printers of the same model, Epson has refined the manufacturing process to include colorimetric calibration. Eliminating the need for internal calibration devices, this system evaluates and adjusts each printer's performance at the manufacturing stage, ensuring consistent color output from printer to printer and print to print. -
Automatic black ink mode switching
With both ink cartridges installed simultaneously, the Epson Stylus Pro series printers automatically utilize the optimal ink mode, delivering maximum density for the chosen media. Taking advantage of the Epson MicroPiezo TFP auto-sharing ink channel ensures a fast and efficient switch. And to further reduce switching errors, the user confirms the switching process from the front control panel.
- Epson Stylus Pro 7900 - large-format printer - colour - ink-jet - with Epson SpectroProofer 24
- Printer Type
- 24" large-format printer - ink-jet - colour
- 80 kg
- Inkjet Technology
- Epson Micro Piezo TFP
- Ink Palette Supported (Colours)
- 10-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
- Max Media Size
- Roll A1 (61.0 cm)
- Min Media Size (Custom)
- 203.2 mm
- Max Media Size (Custom)
- 610 mm
- Print Speed
- Up to 40 sq.m/hour - draft
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Interface
- USB, LAN
- Media Type
- Plain paper, continuous forms
- Networking
- Print server - Ethernet, Fast Ethernet - internal
- Printer Features
- Borderless printing, EPSON Ultra Micro Dot
- System Requirements
- Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / 2000 / XP
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty (Poland - 2 years on-site)
- 136 cm x 66.7 cm x 121 cm
- Bundled with
- Epson SpectroProofer 24
- Printer Type
- Bundled with
Printer
- Inkjet Technology
- Nozzle Configuration
- 10 x 360 nozzles
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Cartridge Configuration
- 11 individual ink tanks
- Ink Type
- Epson UltraChrome HDR
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 2880 x 1440 dpi
- 2880 x 1440 dpi
- Printer Features
Media Handling
- Media Type
- Max Media Size
- Roll A1 (61.0 cm)
- 203.2 mm
- 610 mm
- Media Sizes
- Roll A1 (61.0 cm)
- Media Thickness Range
- Up to 1.5 mm
- Media Feeders
- 1 x manual - 1 roll - Roll A1 (61.0 cm)
- Networking
- Print server - internal
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (vivid light magenta) , 1 x ink cartridge (light black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (orange) , 1 x ink cartridge (green)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- Regional Warranty Exceptions
- Poland - 2 years on-site
- 136 cm
- 66.7 cm
- 121 cm
- 80 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £16.37 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.78 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.78 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £20.69 |
