The Epson Stylus Pro 7700 is a high quality, super fast, four color large format printer. It is engineered to deliver enhanced productivity and image quality for accurate reproduction of architectural drawings and color presentations, engineering plans, spatial data maps, and "attention-grabbing" point-of-sale displays.A market leader in high quality large format printing, Epson incorporates many of its award-winning print technologies to deliver the world's most advanced four color large format printer.
Two black inks for greater versatility
The ink set includes both Matte and Photo Black inks, which maximises quality on your chosen media, including glossy photo paper. The printer will automatically select the optimum ink to match the media, which adds convenience and productivity whatever you print. -
Our most advanced printhead ever
The new Epson MicroPiezo. -
Colour LCD panel
The bright colour LCD gives you easy control of all aspects of your printer, from ink levels and quick cleaning to paper cutting and job cancellation. With clear buttons and the high-visibility 320x200 pixels colour screen you´re always in charge. -
Barcode printing
Barcode printing makes it easy to keep track of media during changes. Simply print the barcode before the roll is removed, and you´ll know exactly how much is left, so you´ll never have to deal with misprints because there´s not enough paper on the roll. -
Versatile connectivity
These printers are 100Base TX/10Base T Ethernet network-ready, making them easy to install and share across your office or studio. There´s also a USB 2.0 port, with sophisticated compression and decompression technologies for fast data processing. -
New printer driver
The new intuitive printer driver is easy to use and can be customised to give you the look and level of information you want. Choose from various print and media settings, and use the Epson LFP Remote Panel 2 Utility Software for functions from Firmware Updater to Custom Page Setup. -
New layout manager
A number of layout options add efficiency to print jobs created in various applications and sizes. Options include minimising white space to reduce wasted paper, fit to roll and free arrangement. -
Flexible print solution
Delivering high-quality prints for business, POS and education, you can depend on the Epson Stylus Pro 7700 and Epson Stylus Pro 9700 to free up your creativity and improve productivity. Jobs that once needed to be outsourced can be brought in-house and handled faster and more efficiently, and with reliable overnight printing you can always meet the tightest deadlines.
- Epson Stylus Pro 7700 - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 80 kg
- Inkjet Technology
- Epson Micro Piezo TFP
- Ink Palette Supported (Colours)
- 4-ink
- Max Media Size
- A1 Plus (610 x 914 mm), Roll A1 (61.0 cm)
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Interface
- USB, LAN
- Preview Screen Size
- 2.5"
- Language Simulation
- EPSON ESC/P 2, EPSON ESC/P Raster, EPSON ESC/P 3
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista (32/64 bits)
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty (Poland - 2 years on-site)
- 136 cm x 66.7 cm x 121 cm
- Printer Type
Printer
- Inkjet Technology
- 4-ink
- Nozzle Configuration
- 10 x 360 nozzles
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Type
- Epson UltraChrome
- Built-in Devices
- Preview screen
- 2.5"
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 2880 x 1440 dpi
- 2880 x 1440 dpi
Media Handling
- Max Media Size
- Media Feeders
- 1 x manual - 1 roll - Roll A1 (61.0 cm)
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 70 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- OS Required
- Limited warranty - 1 year - on-site
- Regional Warranty Exceptions
- Poland - 2 years on-site
- 10 °C
- 35 °C
- 20 - 80%
- Sound Emission (Operating)
- 50 dBA
- 136 cm
- 66.7 cm
- 121 cm
- 80 kg
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.20 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.20 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £13.68 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £21.18 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £28.88 |
