Epson Stylus Pro 4880, 8 Colour InkJet Printer
Quicklinx: 86PZWS00 Mfr#: C11CA00001A0
A breakthrough in professional imaging
Epson UltraChrome K3 ink with Vivid Magenta delivers stunning, photo-realistic image quality. The 8 colour inkset has the widest possible gamut for a fantastic range of expression, and you'll see subtle shadows and highlights when printing in black and white.
Images are reproduced consistently – even across different printers – in vivid, long-lasting colour.
Amazing detail, smoothness and definition
With Epson you'll enjoy a consistently high standard of detail. The print head features micro-fine nozzles that place uniformly shaped, variable sized ink droplets on the media for incredibly sharp, grain-free images. Innovative image processing improves print quality at all resolutions.
Great results across a wide range of media
Choose from ultra smooth fine art paper, matte finish, gloss finish or even rigid poster board for high quality cut sheet output. You can even produce 4 x 6 inch / 10 x 15 cm prints.
High productivity
Intuitive controls make for easy set-up and operation. High capacity ink cartridges mean less changes and higher throughput – ideal for fast turnarounds or overnight printing.
Low cost of ownership
The wide colour gamut from Epson's 8 colour Ultrachrome K3 ink set combined with large, individual print cartridges means you get optimum ink usage and a lower cost of ownership.
  • A breakthrough in professional imaging
  • Amazing detail, smoothness and definition
  • Great results across a wide range of media
  • High productivity
  • Low cost of ownership
Epson Stylus Pro 4880 - large-format printer - colour - ink-jet
Printer Type
17" large-format printer - ink-jet - colour
39.4 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
8-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
Max Media Size
A2 (420 x 594 mm), ANSI C (432 x 559 mm), Roll (43.2 cm)
Min Media Size (Custom)
203.2 mm x 279 mm
Max Media Size (Custom)
432 mm
Print Speed
Up to 12.8 sq.m/hour - draft - A2 (420 x 594 mm)
Max Resolution (B&W)
2880 x 1440 dpi
Max Resolution (Colour)
2880 x 1440 dpi
Image Enhancement Technology
EPSON Variable-sized Droplet Technology
USB, LAN
Media Type
Plain paper, fine art paper, glossy paper, matte paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Print server - Ethernet, Fast Ethernet - internal
Printer Features
Borderless printing, EPSON Ultra Micro Dot
Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.x, Microsoft Windows Vista / 2000 / XP
Microsoft Certification
Certified for Windows Vista
84.8 cm x 76.5 cm x 35.4 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
8 x 180 nozzles
Minimum Ink Droplet Size
3.5 pl
Ink Cartridge Configuration
8 individual ink tanks
Ink Type
Epson UltraChrome K3 with Vivid Magenta
Print Speed
Wired
USB, LAN
2880 x 1440 dpi
2880 x 1440 dpi
Printer Features
Media Handling
Media Handling
Media Type
Max Media Size
203.2 mm x 279 mm
432 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A2 (420 x 594 mm), ANSI C (432 x 559 mm), 432 x 610 mm, Roll (43.2 cm), Roll (20.3 cm x 27.9 cm)
Media Thickness Range
0.08 mm - 1.5 mm
250 sheets
Media Feeders
1 x manual - 1 roll - Roll (43.2 cm) , 1 x manual - 1 sheet - 432 x 610 mm , 1 x automatic - 250 sheets - 432 x 610 mm
Print server - internal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (vivid light magenta) , 1 x ink cartridge (light black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black)
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power supply - internal
59 Watt
Power Consumption Stand by / Sleep
5 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
50 dB
84.8 cm
76.5 cm
35.4 cm
39.4 kg
86PZ Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.37
86PZ Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.78
86PZ Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.78
86PZ Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.22
86PZ Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £20.69
