Epson Stylus Pro 3880 Colour Inkjet Large Format Printer
Epson 3880 Printer
Quicklinx: 6N8WWS00 Mfr#: C11CA61001BX
Epson UltraChrome K3 Ink with Vivid Magenta uses 9 pigment inks to give your prints a very wide colour gamut and exceptional light fastness. Three levels of black deliver a perfectly balanced grey scale and smooth tonal gradations, and auto-switching between optimised photo and matte black gives you the best results on your chosen media.
Produce borderless photos from 4" up to 17" wide and any length you define, up to 37.4". Print on a wide variety of photo, fine art and proofing media, and add flexibility with three cut-sheet paper paths that handle media and posterboard up to 1.5 mm in thickness. This is perfect for POS applications and with the compact footprint retailers can easily fit this printer in store or office.
The Epson Stylus Pro 3880 is also ideal for remote proofing. Prints are so consistent that you can sign-off proofs quickly, certain that what you see is what you will get in the final print run.
With the excellent colour stability and light fastness of Epson UltraChrome K3 Ink with Vivid Magenta, you can create long-lasting prints to sell or exhibit. Exceptional accuracy ensures that each reprint will match the first, even if printed months apart.
Epson Stylus Pro 3880 - large-format printer - colour - ink-jet
Printer Type
17" large-format printer - ink-jet - colour
19.8 kg
Inkjet Technology
Epson Micro Piezo with Active Meniscus Control (AMC)
Ink Palette Supported (Colours)
8-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
Max Media Size
A2 (420 x 594 mm), ANSI C (432 x 559 mm)
Max Resolution (B&W)
2880 x 1440 dpi
Max Resolution (Colour)
2880 x 1440 dpi
Image Enhancement Technology
EPSON Variable-sized Droplet Technology
USB, LAN
Language Simulation
EPSON ESC/P 2
Media Type
Plain paper, fine art paper, semimatte coated fibre paper, glossy paper, matte paper
Total Media Capacity
120 sheets
Media Handling
120-sheet input tray, 1-sheet manual tray
Print server - Ethernet, Fast Ethernet - internal
Printer Features
Borderless printing
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Apple MacOS X 10.3.9, Apple MacOS X 10.4.x, Microsoft Windows Vista, Apple MacOS X 10.5.x
Microsoft Certification
Compatible with Windows 7
1-year warranty (Poland - 2 years on-site)
68.4 cm x 37.6 cm x 25.7 cm
Printer Type
Printer
Inkjet Technology
Nozzle Configuration
8 x 180 nozzles
Minimum Ink Droplet Size
3.5 pl
Ink Cartridge Configuration
8 individual ink tanks
Ink Type
Epson UltraChrome K3 with Vivid Magenta
Wired
USB, LAN
2880 x 1440 dpi
2880 x 1440 dpi
Language Simulation
EPSON ESC/P 2
Colour Management Features
ICC Color Profiles
Printer Features
Borderless printing
Media Handling
Media Handling
Media Type
Max Media Size
Borderless Photo Sizes
Super A3/B (330 x 483 mm), 100 x 150 mm, ANSI C (432 x 559 mm), 279 x 356 mm, 127 x 177.8 mm, 203.2 x 254 mm
Media Thickness Range
Up to 1.5 mm
120 sheets
Media Feeders
1 x manual - 1 sheet , 1 x automatic - 120 sheets - A2 (420 x 594 mm)
Print server - internal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (cyan) - 80 ml , 1 x ink cartridge (vivid magenta) - 80 ml , 1 x ink cartridge (yellow) - 80 ml , 1 x ink cartridge (light cyan) - 80 ml , 1 x ink cartridge (vivid light magenta) - 80 ml , 1 x ink cartridge (light black) - 80 ml , 1 x ink cartridge (light light black) - 80 ml , 1 x ink cartridge (photo black) - 80 ml , 1 x ink cartridge (matte black) - 80 ml
Power supply - internal
Frequency Required
50/60 Hz
25 Watt
Power Consumption Stand by / Sleep
5 Watt
Software Included
EPSON CopyFactory, EPSON ColorBase 2.0, EPSON LFP Remote panel software
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Regional Warranty Exceptions
10 °C
35 °C
20 - 80%
Sound Emission (Operating)
39 dBA
68.4 cm
37.6 cm
25.7 cm
19.8 kg
Ink (15)
6N8W Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £15.10
6N8W Epson T5807 Black Ink Cartridge In Stock £40.14
6N8W Epson T5809 Black Ink Cartridge In Stock £44.08
6N8W Epson Stylus Pro 3800 Cyan (80ml) In Stock £45.93
6N8W Epson STY PRO 380O MAINTENANCE TANK In Stock £15.83
6N8W Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) In Stock £12.67
6N8W Epson Stylus Pro 3800 Magenta In Stock £45.93
6N8W Epson EPSON T580B00 INK CARTR.L.MAG. In Stock £39.43
6N8W Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.61
6N8W Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.61
6N8W Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.06
6N8W Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £14.06
6N8W Epson A3+ Glossy Photo Paper In Stock £21.97
6N8W Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £21.97
6N8W Epson A3 Matte Paper Heavyweight 50 sheets In Stock £29.97
Other bundles (1)
6N8W Epson A2 Premium Glossy Photo Paper - 25 Sheets In Stock £37.72
