Convenience and economy
Complete larger projects like panoramics, calendars and photo books more easily – at 17ml, the R2000's cartridge size has been increased by 50 percent for convenience and economy. And with Epson's individual ink system, you only ever need to replace the colour used, saving you money.
Flexible connectivity
Thanks to the Stylus Photo R2000's Wi-Fi connectivity, you can position the printer wherever suits you best, and print easily from your iPhone or iPad using the Epson Print app. You can also connect using Ethernet and USB, or print directly from your digital camera via PictBridge .
High-quality results
Whatever you print, high-quality results are assured with the combination of Epson's inks and Micro Piezo printhead. The printhead delivers a variable droplet size down to 1.5pl for high precision and smooth gradations, while its ink mixing function ensures that colour reproduction is as accurate as possible by preventing the ink from settling. Get vivid, lifelike colours with Epson UltraChromeHiGloss2 ink, which includes red and orange for natural-looking skin tone reproduction.
Complete larger projects like panoramics, calendars and photo books more easily – at 17ml, the R2000's cartridge size has been increased by 50 percent for convenience and economy. And with Epson's individual ink system, you only ever need to replace the colour used, saving you money. -
Thanks to the Stylus Photo R2000's Wi-Fi connectivity, you can position the printer wherever suits you best, and print easily from your iPhone or iPad using the Epson Print app. You can also connect using Ethernet and USB, or print directly from your digital camera via PictBridge . -
- Epson Stylus Photo R2000 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 12.3 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 8-ink - cyan, magenta, yellow, photo black or matte black, red, orange, gloss optimizer
- Max Media Size
- A3 plus (329 x 423 mm), Roll (32.9 cm)
- Min Media Size (Custom)
- 89 mm
- Max Media Size (Custom)
- 329 mm
- Print Speed
- Up to 1.72 min/page - A3 plus (329 x 423 mm)
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Image Enhancement Technology
- EPSON Advanced Variable Sized Droplet Technology (AVSDT)
- Interface
- USB, LAN, Wi-Fi(n), USB host
- Media Type
- Plain paper, continuous forms, DVD discs, CD discs
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later, Microsoft Windows 7 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 62.2 cm x 79.7 cm x 41.8 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (per cartridge)
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson UltraChrome Hi-Gloss2
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 5760 x 1440 dpi
- 5760 x 1440 dpi
- Direct Printing Specifications
- PictBridge
Media Handling
- Media Type
- Max Media Size
- 89 mm
- 329 mm
- Media Sizes
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
- Included Accessories
- Paper roll holder
- Power Device
- Power adapter - internal
- 21 Watt
- Software Included
- EPSON Print CD, EPSON Easy Photo Print, EpsonNet Print
- OS Required
- Limited warranty - 1 year
- 62.2 cm
- 79.7 cm
- 41.8 cm
- 12.3 kg
Ink (5)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £16.37 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.78 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.78 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.22 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £20.69 |
Other bundles (1)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.02 |
