Epson Stylus Photo PX830FWD - multifunction ( fax / copier / printer / scanner ) ( colour )
Quicklinx: 7Q4VWS00 Mfr#: C11CB20301
Flexible freedom: Configuring laptops and computers to print wirelessly is easy with the automatic Wi-Fi set-up. You don't need to know your network settings or connect with a USB cable, the PX830FWD automatically finds the relevant connection settings in order to configure itself. This 4-in-1 is also compatible with Epson iPrint which offers even more flexibility and freedom, allowing you to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs. PC-free photo printing is fast and convenient thanks to the guidance of the large touch-screen and accompanying PictBridge and memory card slots. No more waiting for computers to power up; printing directly from a USB stick or memory card allows greater flexibility and is straightforward.
High performance: This highly efficient all-round printer comes with fast print speeds and double-sided document printing and has the ability to print directly onto suitable CD and DVDs, which you can use to personalise family films and digital photo albums.
Stylish design: The large 19.8cm touch-panel with integrated touch-screen complements a contemporary design. Multi-page documents can be scanned, copied and faxed when fed through the automatic document feeder, which neatly folds away when not in use. The front-loading trays keep paper discreetly stored away and out of sight.
Ideal for photo printing: For anyone who isn't willing to settle for just lab-quality results when printing their photos, Epson's unique Claria Photographic Ink has been developed to deliver better-than-lab-quality results with every print job. You get great value with a choice of cartridge sizes and, with individual inks, you only need to replace the colour used. The ideal partner for the latest DSLR and compact cameras, high quality prints can be achieved every time with this high-definition ink but it's also versatile enough to ensure you can use it for your non-photo printing needs. Additionally, the dual paper trays allow you to effortlessly switch between A4 sized and photo sized paper during printing, by automatically selecting the correct tray.
  • Flexible freedom
  • High performance
  • Stylish design
  • Ideal for photo printing
    For anyone who isn't willing to settle for just lab-quality results when printing their photos, Epson's unique Claria Photographic Ink has been developed to deliver better-than-lab-quality results with every print job. You get great value with a choice of cartridge sizes and, with individual inks, you only need to replace the color used. The ideal partner for the latest DSLR and compact cameras, high quality prints can be achieved every time with this high-definition ink but it's also versatile enough to ensure you can use it for your non-photo printing needs. Additionally, the dual paper trays allow you to effortlessly switch between A4 sized and photo sized paper during printing, by automatically selecting the correct tray.
Epson Stylus Photo PX830FWD - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 6-ink
Max Printing Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi
Scanning
4800 x 4800 dpi
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD disc
Standard Media Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Print from memory card
AC 230 V (50/60Hz)
46.5 cm x 45.8 cm x 19.8 cm
11.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour - photo
Display Features
Touch screen
Supported Flash Memory
Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO, IBM Microdrive, MultiMediaCardplus, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
6 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, light cyan, light magenta
6-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Photographic Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 180 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets, books
30 sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
120 sheets
Input tray - 120 sheets - Legal (216 x 356 mm) , Input tray - 20 sheets , ADF - 30 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 95 g/m²
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 40 ppm (A4) - colour , Printing: 10 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, WPA2, TKIP, AES
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
Software Included
Epson Event Manager, EPSON Print CD, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac, Epson Fax Utility
AC 230 V (50/60Hz)
23 Watt
Power Consumption Standby
11 Watt
Power Consumption Sleep
5 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta)
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60950-1, TBR21, EN 300 328, EN 301 489-1, EN 301 489-17
ENERGY STAR Certified
Limited warranty - 1 year
46.5 cm
45.8 cm
19.8 cm
11.4 kg
Shipping Width
56 cm
Shipping Depth
53.4 cm
Shipping Height
30.6 cm
Shipping Weight
14.1 kg
Sound Emission
35 dBA (operating)
10 °C
35 °C
20 - 80%
7Q4V Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.37
7Q4V Epson T0806 Ink Cartridge - Light Magenta In Stock £9.59
7Q4V Epson T080 Stylus Photo Light Cyan Ink Cartridge In Stock £9.59
7Q4V Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.78
7Q4V Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.78
7Q4V Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.22
