Epson Stylus Office BX525WD
Epson Stylus Office BX525WD Printer
Quicklinx: 7C0DWS00 Mfr#: C11CA70311
Impressive speed:
When printing in black, you'll appreciate a high print speed of up to 15 pages per minute (based on ISO/IEC24734)**3.
Wi-Fi and Ethernet enabled:
Multiple users will be able to print and scan over a network whether using Ethernet or the latest 802.11n wireless technology*4.
Less paper, less waste:
With automatic double-sided printing that is fastest in its class*2, this is a wireless printer that allows you to use less paper, which is better for the environment and keeps running costs down.
High quality printing for professional results:
Our fast-drying DURABrite Ultra Inks ensure laser-like text, vibrant colours and resist water, smudging, fading and highlighter pens, so documents, graphs and maps are perfectly produced.
Economical ink:
We offer a choice of cartridges to meet your printing needs, including XL inks for high volume, low-cost, colour printing, which cost up to 50% less than laser printers*5
Simple navigation
Full functionality and control is at your fingertips with the 6.3cm colour LCD viewer. Scan documents to PDF or email attachments directly to a PC via Wi-Fi or Ethernet.
Elegant design
The high-capacity front-loading paper tray means this printer fits smoothly into any office environment.
This product meets the strict ENERGY STAR guidelines set by the European Commission. Epson is a global manufacturer committed to protecting the environment for future generations by offering a range of ENERGY STAR products. This is achieved by significantly reducing electricity usage, which saves energy, money and the environment, without compromising quality.
  • Impressive speed
    When printing in black, you'll appreciate a high print speed of up to 15 pages per minute (based on ISO/IEC24734).
  • Wi-Fi and Ethernet enabled
    Multiple users will be able to print and scan over a network whether using Ethernet or the latest 802.11n wireless technology.
  • Less paper, less waste
    With automatic double-sided printing that is fastest in its class, this is a wireless printer that allows you to use less paper, which is better for the environment and keeps running costs down.
  • High quality printing for professional results
  • Economical ink
    We offer a choice of cartridges to meet your printing needs, including XL inks for high volume, low-cost, colour printing, which cost up to 50% less than laser printers.
  • Simple navigation
  • Elegant design
Epson Stylus Office BX525WD - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 15 ppm (mono) / up to 7.1 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
2400 x 2400 dpi
Display
2.5"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Plain paper, photo paper
Standard Media Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Print from memory card
AC 230 V (50/60Hz)
45.5 cm x 35.9 cm x 16.4 cm
6.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.5"
Supported Flash Memory
Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 2400 dpi
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Borderless Photo Sizes
100 x 150 mm
150 sheets
Input tray - 150 sheets
Speed Details
Printing: up to 36 ppm (A4) - B/W , Printing: up to 36 ppm (A4) - colour , Printing: 20 sec (10 x 15 cm (4"x6")) - photo , Printing: up to 15 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 7.1 ppm (A4) - colour (ISO/IEC 24734)
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, EpsonNet Setup Manager, Presto! PageManager 9
AC 230 V (50/60Hz)
15 Watt
Power Consumption Standby
3.4 Watt
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black)
ENERGY STAR Certified
Limited warranty - 1 year
45.5 cm
35.9 cm
16.4 cm
6.2 kg
Sound Emission
38 dBA (operating)
7C0D Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.66
7C0D Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.99
7C0D Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.99
