Epson Stylus Office BX320FW - Wireless Multifunction ( fax / copier / printer / scanner ) ( colour )
Epson BX320FW Printer
Quicklinx: 7B4PWS00 Mfr#: C11CA78301
Impressive speed and print quality are just two good reasons to invest in the wireless 4-in-1 that prints, scans, copies and faxes. With a 30 page automatic document feeder, a fax facility with five speed dials plus a two line LCD control panel, this affordable printer will be the perfect addition to your home office.
Boost productivity
The Automatic Document Feeder makes light work of scanning, copying and faxing multiple pages. And when printing in black and white, you'll appreciate a high print speed of up to 15 pages per minute (based on ISO/IEC24734).
Wi-Fi and Ethernet enabled
Whether using the latest 802.11n high-speed Wi-Fi*³ or utilising Ethernet, multiple users can print, scan and fax over a network.
High quality printing for professional results
Our fast-drying DURABrite Ultra Inks ensure laser-like text, vibrant colours and resist water, smudging, fading and highlighter pens, so documents, graphs and maps are perfectly produced.
Economical ink
Epson's colour costs less - up to 50% lower than laser competitors.
Simple navigation
Both copying and faxing are easy with the control panel and two line text LCD display, while the fax function is given a further boost by the five speed dial buttons, so key contacts can be faxed in an instant.
Epson Stylus Office BX320FW - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 15 ppm (mono) / up to 5.5 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
120 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AC 230 V
46 cm x 40.3 cm x 23.5 cm
7.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display
2 lines
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
360 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 180 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
30 sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
120 sheets
Input tray - 120 sheets - Legal (216 x 356 mm) , ADF - 30 sheets - A4 (210 x 297 mm) weight: 75 g/m² - 95 g/m²
Speed Details
Printing: up to 38 ppm (A4) - B/W draft , Printing: up to 20 ppm (A4) - colour draft , Printing: 49 sec (10 x 15 cm (4"x6")) - photo , Printing: up to 15 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 5.5 ppm (A4) - colour (ISO/IEC 24734)
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, WPA, WPA2
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, EpsonNet Setup Manager, Epson Fax Utility, Presto! PageManager 9
AC 230 V
15 Watt
Power Consumption Sleep
4 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year
46 cm
40.3 cm
23.5 cm
7.4 kg
Sound Emission
39 dBA (operating)
7B4P Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.29
7B4P Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.72
7B4P Epson A4 Iron On Transfer Pack 10sht In Stock £14.40
7B4P Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.79
7B4P Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.14
