Epson Stylus Office BX305FW Plus - multifunction ( fax / copier / printer / scanner ) ( colour )
Quicklinx: 7X1PWS00 Mfr#: C11CB45301
This entry-level 4-in-1 is big on affordability and flexibility, making it ideal for small businesses that need to scan, print, copy and fax while keeping costs to a minimum.
Savings: Individual DURABrite Ultra Ink cartridges save you money as you only replace the colours used.
Flexible: The BX305FW Plus offers both flexibility and freedom with secure wireless printing and an integrated memory card reader accessed via a PC. Epson iPrint allows users to quickly and easily print documents wirelessly from smartphones and tablet PCs
Efficient: Boost productivity by printing up to 34 pages per minute in draft mode and save time with a 30-page automatic document feeder allowing multi-page documents to be scanned and copied. Five dedicated speed dial fax buttons allow users to store frequently used numbers, while an LCD screen means fast and easy copying and faxing.
4-in-1
Print, scan, copy and fax
Economical
Save money with individual inks
Quality results
Laser-like text and vibrant colours
Wireless printing
Wi-Fi and Epson iPrint
Efficient
  • Savings
    Individual DURABrite Ultra Ink cartridges save you money as you only replace the colors used.
  • Flexible
    The BX305FW Plus offers both flexibility and freedom with secure wireless printing and an integrated memory card reader accessed via a PC. Epson iPrint allows users to quickly and easily print documents wirelessly from smartphones and tablet PCs.
  • Efficient
Epson Stylus Office BX305FW Plus - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 34 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
120 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
Office Machine Features
Print from memory card
AC 230 V
46 cm x 41.1 cm x 23.5 cm
7.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display
2 lines
USB 2.0, Wi-Fi(n)
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, MultiMediaCardplus, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
128 nozzles (black), 3 x 42 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Broadcast Transmission
Yes (black only)
Delayed Transmission
Group dialling
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
30 sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
120 sheets
Input tray - 120 sheets - Legal (216 x 356 mm) , ADF - 30 sheets - A4 (210 x 297 mm) weight: 75 g/m² - 95 g/m²
Speed Details
Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 15 ppm (A4) - colour draft
1 x USB 2.0
Security Protocols & Features
WEP, WPA-PSK, WPA2
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
Software Included
Epson Easy Photo Print, Epson Fax Utility, Presto! PageManager 9
AC 230 V
15 Watt
Power Consumption Sleep
3.7 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year
46 cm
41.1 cm
23.5 cm
7.1 kg
Sound Emission
38 dBA (operating)
7X1P Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.53
