Epson Stylus Office B42WD Wifi Duplex
Epson B42WD
Quicklinx: 7FFPWS00 Mfr#: C11CA77301
Economical printing: This is a printer designed to save time and money while delivering high-quality professional results. It is affordable and cost-per-page is up to 50 percent lower than competitive laser printers1. Costs are kept low as Epson's individual ink cartridge system means only the colour used needs to be replaced, while further savings can be made thanks to a choice of different cartridge sizes including XL 'Stag' inks for high volume, low-cost printing. Automatic duplexing helps to cut paper usage by up to 50 percent, further reducing costs and environmental impact.
Boost productivity: Productivity is increased with a business-quality print speed of 15 black and 7.1 colour pages per minute (ISO/IEC 24734)2 and up to 38 pages per minute in draft3 mode. With no warm-up time required, results are delivered at high speed, and a high-capacity 250-sheet front-loading paper tray means less time is spent refilling.
Easy access: A straightforward and easy to use printer, the B42WD has built-in Wi-Fi and Ethernet connectivity.
Built for business: Business documents of all types can be printed with confidence with Epson's DURABrite Ultra Ink, delivering sharp, laser-like text and vibrant colours, with a finish which is water, smudge, fade and highlighter resistant.
  • Economical printing
    This is a printer designed to save time and money while delivering high-quality professional results. It is affordable and cost-per-page is up to 50 percent lower than competitive laser printers1. Costs are kept low as Epson's individual ink cartridge system means only the color used needs to be replaced, while further savings can be made thanks to a choice of different cartridge sizes including XL 'Stag' inks for high volume, low-cost printing. Automatic duplexing helps to cut paper usage by up to 50 percent, further reducing costs and environmental impact.
  • Boost productivity
    Productivity is increased with a business-quality print speed of 15 black and 7.1 color pages per minute (ISO/IEC 24734)2 and up to 38 pages per minute in draft3 mode. With no warm-up time required, results are delivered at high speed, and a high-capacity 250-sheet front-loading paper tray means less time is spent refilling.
  • Easy access
  • Built for business
    Business documents of all types can be printed with confidence with Epson's DURABrite Ultra Ink, delivering sharp, laser-like text and vibrant colors, with a finish which is water, smudge, fade and highlighter resistant.
Epson Stylus Office B42WD - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
4.5 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 38 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
Automatic Duplexing
USB, LAN, Wi-Fi(n)
Media Type
Envelopes, plain paper
Total Media Capacity
250 sheets
Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later
Microsoft Certification
Compatible with Windows 7
1-year warranty
44.5 cm x 33 cm x 15.4 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
Minimum Ink Droplet Size
2 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Wireless
USB, LAN, Wi-Fi(n)
5760 x 1440 dpi
5760 x 1440 dpi
Automatic Duplexing
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 200 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
250 sheets
Print server
Security Protocols & Features
WEP, WPA-PSK
1 x USB 2.0 - 4 pin USB Type A , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Power supply - internal
16 Watt
Power Consumption Stand by / Sleep
3 Watt
Software Included
EPSON Easy Photo Print
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Operating)
40 dBA
44.5 cm
33 cm
15.4 cm
4.5 kg
7FFP Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.37
7FFP Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.78
7FFP Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.78
7FFP Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.22
