An economical and versatile paper, this is the perfect solution for affordable, high quality output from the Epson Stylus Pro series wide-format printers. Uses include promotional pieces, comps, professional layouts, indoor signage, proofs, displays and posters.A low-cost alternative for high-resolution output, this paper is compatible with both dye and pigment ink. With instant ink drying for added convenience, it can also be easily laminated for a glossy-finished look and as a method of protection from excessive light and moisture.Like all of our innovative media, this paper is engineered to give you the highest resolution and colour saturation possible. Epson's printer driver software actually optimises the amount of ink released onto the page, based on the type of paper used. As always, Epson supplies guarantee Epson quality.This paper is certified for Digigraphie use, being tested by independent laboratories to guarantee the stability of prints over time.
 - Epson Singleweight Matte - paper - matte - 1 roll(s) - Roll A1 (61 cm x 40 m) - 120 g/m²
- Product Type
 - Paper
- Surface Finish
 - Matte
- Media Size
- Printing Technology
 - Ink-jet
- Media Weight
 - 120 g/m²
- Included Qty
 - 1 roll(s)
- Compatible with
 - Stylus Pro 11880, Pro 7700, Pro 78XX, Pro 7900, Pro 9700, Pro 98XX, Pro 9900, Pro WT7900; SureColor SC-P10000, P20000, P6000, P7000, P7500, P8000, P9000, P9500, T2100, T3000, T3100, T3200, T3400, T3405, T5000, T5100, T5200, T5400, T5405, T7000, T7200, T3000, T3160, T5000, T5160, T7000
Media
- Media Type
 - Paper
- Surface Finish
 - Matte
- Media Sizes
 - Ink-jet
- Included Qty
 - 1 roll(s)
- Media Weight
 - 120 g/m²
- Compatible with
 - Epson Stylus Pro 11880, Pro 11880 AGFA, Pro 11880 ColorBurst Edition, Pro 11880 Xerox, Pro 7700, Pro 7880, Pro 7880 ColorBurst Edition, Pro 7890, Pro 7890 AGFA, Pro 7890 Designer Edition, Pro 7900, Pro 9700, Pro 9880, Pro 9880 ColorBurst Edition, Pro 9890, Pro 9890 AGFA, Pro 9890 Designer Edition, Pro 9900, Pro 9900 AGFA, Pro 9900 Proofing Edition, Pro WT7900, Pro WT7900 Designer Edition , Epson SureColor SC-P10000, SC-P20000, SC-P6000, SC-P7000, SC-P7000V, SC-P7500, SC-P7500 Spectro, SC-P8000, SC-P9000, SC-P9000V, SC-P9500, SC-P9500 Spectro, SC-T2100, SC-T3000, SC-T3000 POS, SC-T3000 w/o stand, SC-T3100, SC-T3100M, SC-T3100N, SC-T3100X, SC-T3200, SC-T3200 w/o stand, SC-T3200-PS, SC-T3400, SC-T3400N, SC-T3405, SC-T3405N, SC-T5000, SC-T5000 POS, SC-T5100, SC-T5100M, SC-T5100N, SC-T5200, SC-T5200D, SC-T5200DMFP, SC-T5200D-PS, SC-T5200MFP, SC-T5200-PS, SC-T5400, SC-T5400M, SC-T5405, SC-T7000, SC-T7000 POS, SC-T7200, SC-T7200 MFP, SC-T7200D, SC-T7200D MFP, SC-T7200D-PS, SC-T7200-PS, T3000 Standard Edition, T3160, T3160M, T5000 Standard Edition, T5160M, T7000 Standard Edition
