RUNSENSE GPS SPORTS MONITORS’ KEY FEATURES LET YOU PLAN YOUR TRAINING AND MONITOR YOUR PERFORMANCE LIKE NEVER BEFORE
Runsense combines highly accurate GPS tracking with a built-in Smart Stride Sensor1 to learn your technique and measure your distance. You can view real time data at a glance on four customisable screens, with up to 30 hours of GPS monitoring. Dare yourself to run another mile.
Accurate Epson GPS Sensor
Epson has been developing GPS components for smartphones and other industrial devices for many years. Runsense is built around a new highly accurate and energy-efficient GPS chip.
Learns your individual technique, calibrating your stride length accurately while you run with full GPS signal coverage. If GPS signal is lost due to overhead cover or interference, such as running through woodland or near tall buildings, Runsense will continue to track distance and pace data.
Long Battery Life
Thanks to the Epson developed GPS chip and product architecture, you can run for longer without recharging. Features a battery life of up to 30 hours of GPS tracking, which is up to three times longer than comparable competitor products2.
Assignable Tap Function
Runsense provides you with flexible features and controls, like the tap functionality that allows you to scroll through four customisable screens - providing real time data- turn on the light or set laps.
Customise the four displays your way with up to three measurements per screen. You can even select and save settings through the Run Connect app making it quick and easy to customise your device for specific workouts.
Analyse and Evaluate Runs with the Epson Runsense View Portal
Analyse your exercise in detail, share your achievements with others and set achievable targets designed to improve your performance. Dare to push yourself further with the Epson Runsense View Portal and Run Connect app.
Water Resistant
Water resistant to 5 bar means you don’t need to worry about running in the wet. In fact, you can even swim wearing Runsense without an issue.
Compact Lightweight Design
Its compact, lightweight design is comfortable to wear and does not sacrifice screen size so its easy to read while on the run.
1 Only available on the SF-510 and above.
2 Compared to Garmin and TomTom devices checked on 1/7/2014.
Sports GPS with Smart Stride
Runsense GPS sports monitors let you plan your training and accurately monitor your performance.
- Epson SF-510F - GPS navigator
- Product Type
- GPS navigator
- Display
- 128 x 96 pixels
- Recommended Use
- Hiking, cycle, running
- Interface
- USB, Bluetooth
- Ambient light sensor, heart rate, smart stride sensor
- Tracking Data
- Distance
- Protection
- Waterproof
- Included Accessories
- Cradle
- 4.43 cm x 1.18 cm
- 48.9 g
- 1-year warranty
- Product Type
- GPS navigator
- Recommended Use
- Interface
- USB, Bluetooth
- Tracking Data
- Distance
- Clock, timer, AutoLap, calorie computation, ambient light sensor, heart rate, smart stride sensor
Display
- LCD
- Display Width
- 2.82 cm
- Display Height
- 2.16 cm
- Display Resolution
- 128 x 96 pixels
- USB
- Protection
- Waterproof
- Cradle
- 4.43 cm
- 1.18 cm
- 48.9 g
- 1-year warranty
