The genuine Epson ELPLP77 ultra high efficiency (UHE) projector lamp is designed to replace the original genuine Epson projector lamp included with the Epson PowerLite projectors.
Enhanced brightness
The UHE lamp type in the Epson ELP LP77 projector lamp ensures your presentations are vivid and bright, suitable for any setting, from classrooms to boardrooms. -
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup, ensuring a hassle-free experience whether you're presenting or streaming.
- Epson ELPLP77 - projector lamp
- Product Type
- Projector lamp - UHE
- Designed For
- Epson EB-1970W, EB-1975W, EB-1980WU, EB-1985WU, EB-4550, EB-4650, EB-4750W, EB-4770W, EB-4850WU, EB-4950WU; PowerLite 4650, 4750W, 4855WU
- Product Type
- Projector lamp
Lamp
- UHE
- Designed For
- Epson EB-1970W, EB-1975W, EB-1980WU, EB-1985WU, EB-4550, EB-4650, EB-4750W, EB-4770W, EB-4850WU, EB-4950WU , Epson PowerLite 4650, 4750W, 4855WU
