Epson RC-T5YNA 50mm Yellow Tape
Quicklinx: 8RN8WS00 Mfr#: C53S634003
Type: Glossy tape
Technology: Thermal transfer
£22.96 ex VAT
£27.55 inc VAT
Choose between seven different coloured 50mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
  • Versatile compatibility
    Designed to seamlessly integrate with PC systems, this product ensures a smooth and efficient printing experience for all your labeling needs.
  • Durable design
    Crafted from high-quality polyolefin, the RC-T5YNA plastic tape is built to withstand a variety of environmental conditions, making it suitable for both indoor and outdoor applications.
  • Easy application
    Thanks to its self-adhesive backing, applying your labels, cards, and stickers is as simple as peeling and sticking, ensuring a secure fit on a wide range of surfaces.
Epson RC-T5YNA - plastic tape - 1 roll(s) - Roll (5 cm x 15 m)
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Size
Roll (5 cm x 15 m)
Media Colour
Yellow
Included Qty
1 roll(s)
Compatible with
LabelWorks Pro100
Media
Media Type
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Sizes
Roll (5 cm x 15 m)
Media Colour
Yellow
Included Qty
1 roll(s)
Colour Category
Yellow
Compatible with
Epson LabelWorks Pro100
Type: Glossy tape
Brand: Epson
