Epson RC-T5WNA 50mm White Tape
Quicklinx: 8RN6WS00 Mfr#: C53S634001
Choose between seven different coloured 50mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
  • Versatile compatibility
    Designed to seamlessly integrate with PC systems, this Epson RC-T5WNA printing media ensures a smooth and efficient printing experience for a variety of projects.
  • Durable design
    Crafted from high-quality polyolefin, the Epson RC-T5WNA plastic tape is built to last, resisting wear and tear for reliable, long-term use.
  • Easy application
    Featuring a self-adhesive backing, this roll of plastic tape allows for quick and secure attachment to a wide range of surfaces, simplifying your labeling and organizing tasks.
Epson RC-T5WNA - plastic tape - 1 roll(s) - Roll (5 cm x 15 m)
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Size
Roll (5 cm x 15 m)
Media Colour
White
Included Qty
1 roll(s)
Compatible with
LabelWorks Pro100
Media
Media Type
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Sizes
Roll (5 cm x 15 m)
Media Colour
White
Included Qty
1 roll(s)
Colour Category
White
Compatible with
Epson LabelWorks Pro100
