Choose between seven different coloured 50mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
Versatile compatibility
Designed to seamlessly integrate with PC systems, this Epson RC-T5WNA printing media ensures a smooth and efficient printing experience for a variety of projects. -
Durable design
Crafted from high-quality polyolefin, the Epson RC-T5WNA plastic tape is built to last, resisting wear and tear for reliable, long-term use. -
Easy application
Featuring a self-adhesive backing, this roll of plastic tape allows for quick and secure attachment to a wide range of surfaces, simplifying your labeling and organizing tasks.
- Epson RC-T5WNA - plastic tape - 1 roll(s) - Roll (5 cm x 15 m)
- Product Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Size
- Media Colour
- White
- Included Qty
- 1 roll(s)
- Compatible with
- LabelWorks Pro100
Media
- Media Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Sizes
- Media Colour
- White
- Included Qty
- 1 roll(s)
- Colour Category
- White
- Compatible with
- Epson LabelWorks Pro100
