Choose between seven different coloured 50mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
Versatile compatibility
Designed to seamlessly integrate with PC systems, this printing media ensures a smooth and efficient printing process for a variety of projects. -
Durable design
Crafted from high-quality polyolefin, the RC-T5TNA plastic tape is built to last, resisting wear and tear for long-lasting use. -
Easy application
Featuring a self-adhesive backing, this plastic tape can be easily applied to a wide range of surfaces, making it ideal for creating labels, stickers, and cards.
- Epson RC-T5TNA - plastic tape - 1 roll(s) - Roll (5 cm x 15 m)
- Product Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Size
- Media Colour
- Transparent
- Included Qty
- 1 roll(s)
- Compatible with
- LabelWorks Pro100
Media
- Media Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Sizes
- Media Colour
- Transparent
- Included Qty
- 1 roll(s)
- Colour Category
- Transparent
- Compatible with
- Epson LabelWorks Pro100
