Epson RC-T5RNA 50mm Red Tape
Quicklinx: 8RN9WS00 Mfr#: C53S634004
Choose between seven different coloured 50mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
  • Versatile compatibility
    Designed to seamlessly integrate with PC systems, this product ensures an efficient printing experience for a variety of projects.
  • Durable design
    Crafted from polyolefin, the RC-T5RNA labels offer a robust solution for your labeling needs, resisting wear and tear in various environments.
  • Easy application
    Thanks to its self-adhesive feature, applying these labels to your desired surfaces is hassle-free, eliminating the need for additional adhesives.
Epson RC-T5RNA - plastic tape - 1 roll(s) - Roll (5 cm x 15 m)
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Size
Roll (5 cm x 15 m)
Media Colour
Red
Included Qty
1 roll(s)
Compatible with
LabelWorks Pro100
Media
Media Type
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Sizes
Roll (5 cm x 15 m)
Media Colour
Red
Included Qty
1 roll(s)
Colour Category
Red
Compatible with
Epson LabelWorks Pro100
