Epson RC-T5LNA 50mm Blue Tape
Quicklinx: 8RNBWS00 Mfr#: C53S634005
Choose between seven different coloured 50mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
  • Versatile compatibility
    Designed to integrate seamlessly with PC systems, the Epson RC-T5LNA printing media ensures a smooth and efficient printing experience for a variety of projects.
  • Durable design
    Made from high-quality polyolefin, the plastic tape is self-adhesive and engineered to withstand daily use, making it suitable for both professional and personal applications.
  • Optimal size
    The roll measures 5 cm x 15 m, providing ample length for numerous printing tasks without the need for frequent replacements, ensuring your projects continue uninterrupted.
Epson RC-T5LNA - plastic tape - 1 roll(s) - Roll (5 cm x 15 m)
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Size
Roll (5 cm x 15 m)
Media Colour
Blue
Included Qty
1 roll(s)
Compatible with
LabelWorks Pro100
Media
Media Type
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Sizes
Roll (5 cm x 15 m)
Media Colour
Blue
Included Qty
1 roll(s)
Colour Category
Blue
Compatible with
Epson LabelWorks Pro100
