Choose between seven different coloured 100mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
- Epson RC-T1WNA - plastic tape - 1 roll(s)
- Product Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Size
- Roll (10 cm x 15 m)
- Media Colour
- White
- Included Qty
- 1 roll(s)
- Compatible with
- LabelWorks Pro100
Media
- Media Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Sizes
- Media Colour
- White
- Included Qty
- 1 roll(s)
- Colour Category
- White
- Compatible with
- Epson LabelWorks Pro100
