Epson RC-T1LNA 100mm Blue Tape
Quicklinx: 8RN2WS00 Mfr#: C53S633005
Choose between seven different coloured 100mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
  • Versatile compatibility
    Designed to seamlessly integrate with PC systems, this Epson RC-T1LNA printing media ensures a smooth and efficient printing experience for a variety of projects.
  • Durable design
    Crafted from high-quality polyolefin, the plastic tape is not only self-adhesive but also engineered to withstand various environmental conditions, making it ideal for both indoor and outdoor applications.
  • Optimal size
    The roll measures 10 cm x 15 m, providing ample length for extensive printing needs while ensuring compatibility with a wide range of projects, from cards and labels to stickers.
Epson RC-T1LNA - plastic tape - 1 roll(s) - Roll (10 cm x 15 m)
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Size
Roll (10 cm x 15 m)
Media Colour
Blue
Included Qty
1 roll(s)
Compatible with
LabelWorks Pro100
Media
Media Type
Plastic tape
Product Material
Polyolefin
Adhesive Type
Self-adhesive
Media Sizes
Roll (10 cm x 15 m)
Media Colour
Blue
Included Qty
1 roll(s)
Colour Category
Blue
Compatible with
Epson LabelWorks Pro100
