Choose between seven different coloured 100mm wide Olefin plastic tapes. At 15m in length, these tapes allow you to create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
Versatile compatibility
Designed to seamlessly integrate with PC systems, this product ensures a smooth and efficient printing experience for all your labeling needs. -
Durable design
Crafted from high-quality polyolefin, the RC-T1BNA plastic tape is built to withstand a variety of environmental conditions, making it ideal for both indoor and outdoor applications. -
Easy application
Featuring a self-adhesive backing, this printing media allows for quick and secure attachment to a wide range of surfaces without the need for additional adhesives.
- Epson RC-T1BNA - plastic tape - 1 roll(s) - Roll (10 cm x 15 m)
- Product Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Size
- Media Colour
- Black
- Included Qty
- 1 roll(s)
- Compatible with
- LabelWorks Pro100
Media
- Media Type
- Plastic tape
- Product Material
- Polyolefin
- Adhesive Type
- Self-adhesive
- Media Sizes
- Media Colour
- Black
- Included Qty
- 1 roll(s)
- Colour Category
- Black
- Compatible with
- Epson LabelWorks Pro100
