Epson RC-R1RNA 100mm Red Ribbon
Quicklinx: 8RNJWS00 Mfr#: C53S635004
Choose between five different coloured 30m long ink ribbons to use with LabelWorks Pro100 Olefin plastic tapes.
Create hazard signs, large identification labels or other signage around the office or warehouse.
Thanks to the 300 dpi print resolution, high-quality, durable labels are easy to create.
  • Efficient printing
    Designed for seamless integration with PC systems, the Epson RC-R1RNA print ribbon utilizes advanced thermal transfer technology to ensure high-quality printing results. Its compatibility with a wide range of printing consumables makes it a versatile choice for various printing needs.
  • Long-lasting performance
    With a ribbon length of 30 m and a width of 100 mm, this print ribbon is crafted to deliver long-lasting performance, reducing the need for frequent replacements and ensuring uninterrupted printing operations.
Epson RC-R1RNA - 1 - red - print ribbon
Print ribbon
Printing Technology
Thermal transfer
Printing Colour
Red
Included Qty
1
Ribbon Size
100 mm x 30 m
Compatible with
LabelWorks Pro100
Consumable
Consumable Type
Print ribbon
Printing Technology
Thermal transfer
Red
Included Qty
1
Ribbon Size
100 mm x 30 m
Compatible with
Epson LabelWorks Pro100
