The portable Connect Floor is one of the best-selling Euroscreen products and is a favourite with many customers. Compared to other portable screens the Connect Floor is sturdier, often more practical, and contains fewer parts than a tripod screen. The steel cassette rests steadily on the floor supported by a "foot" and provides an available viewing area from the cassette to the top of the raised viewing surface. The model is very easy to set up, light-weight and integrated handle makes it easy to carry along.
Connect Floor is also perfect for custom graphic print - personal printed messages at the focal point at all time for large audiences.
- Euroscreen Connect Floor 16:10 Format - projection screen - 114" (290 cm)
- Product Type
- Projection screen
- White
- Projection Screen Image Diagonal Size
- 114" (290 cm)
- Projection Image Size
- 200 cm x 210 cm
- Aspect Ratio
- 16:10
- Screen Surface
- Arctiq
- 11 kg
- Product Type
- Projection screen
- Image Diagonal Size
- 114" (290 cm)
- Image Width
- 200 cm
- Image Height
- 210 cm
- Screen Surface
- Arctiq
- Aspect Ratio
- 16:10
- Gain
- 1.0x
- Viewing Angle
- 180°
- Screen Thickness
- 0.37 mm
- Mildew-resistant, washable, flame retardant
- 11 kg
- White
