Epson Perfection V850 Pro Flatbed Scanner
Quicklinx: B5SKWS00 Mfr#: B11B224401BY
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: 216 x 297 mm
Interface: USB 2.0
Compatibility: Mac, PC
£768.48 ex VAT
£922.17 inc VAT
Choice of resolution
The V850 Pro features a dual lens system that automatically selects the optimal lens, with up to 4800dpi optical resolution for photo scanning and 6400dpi when scanning using film holders.
Scan from any source
Scan a range of film formats in sharp focus thanks to the improved quality film holders with their adjustable height control and rigid design. The V850 Pro also supports film formats up to 8x10 inch when placed directly on the scanner glass.
High productivity
Epson's ReadyScan LED light source has a warm up time of less than one second, so scanning can start almost instantly. Two sets of film holders means you can prepare a second set of orginals for scanning while the first is still scanning.
Cleans-up images
Digital ICE Technologies automatically removes imperfections such as dust, hair, scratches and fingerprints from both film and photos to restore images to their former glory with the minimum of effort.
The right tone
Take advantage of excellent tone reproduction with 4.0 DMax optical density.The V850 Pro can detect the exact tonal range of the original, making sure the brightest and darkest areas of images are accurately reproduced to reveal impressive detail and dynamic range.
Professional software
As well as Epson Scan, the V850 Pro comes with SilverFast SE Plus 8 and i1 Scanner software for advanced, professional scanning features.
  • Perfection V850 Pro scanner
    Professional photographers and serious amateurs can reproduce their film and photos in high quality.
  • PROFESSIONAL-QUALITY SCANNING WITH THE PERFECTION V850 PRO
    Your photographs and films will have never looked so good with the latest V850 Pro scanner from Epson. Ideal for professional photographers and serious amateurs, this dual-lens, high-resolution scanner converts a wide range of media and film into superb digital images. It features an enhanced optical system to help create superior-quality images at fast scan speeds. This high-productivity scanner requires virtually no warm-up time and comes with two sets of professional-quality film holders to help you scan quicker. The V850 Pro can also remove dust and scratches automatically from photos and film and includes a professional software package to help you achieve outstanding results.
  • Optimum film and photo scanning
    The V850 Pro's dual lens system automatically selects the optimal lens for whatever media you are wishing to scan. With up to 4800dpi optical resolution for photo scanning and up to 6400dpi when scanning using film holders, high-quality results are guaranteed.
  • Improved film holders
    Our new and improved professional-quality film holders now provide a greater degree of control and accuracy, as the height at which the film sits above the scanner bed can be finely adjusted to achieve the sharpest focus possible. The holders' rigid frames, combined with anti-Newton ring plates, also gives a flatter hold for further quality improvements. The V850 Pro comes with two sets of film holders, meaning you can prepare a second set of originals for scanning while the first is still scanning, increasing your productivity.
  • Automatically remove imperfections
    Make sure your photos and film look their best without the painstaking effort of manual retouching. Digital ICE technology automatically removes the appearance of dust, hairs, scratches and fingerprints from film scans to restore images to their former glory. The technology also works on photos and even removes the appearance of creases and rips/tears to help your old photographs look as good as new again.
  • Virtually no warm-up time
    Don't waste time waiting to start scanning. Our ReadyScan LED Technology means warm-up time is less than one second so you can start scanning instantly.
  • Accurate tones
    The scanner has an optical density of 4.0DMax, allowing it to capture even small differences in tone from the brightest area (white) to the darkest area (black). This means it can reproduce the tone from the original film and photographs, giving you clear and accurate results.
  • High quality and speed
    The scanners' enhanced optical system (High Pass Optics) utilises anti-reflective lens coatings and a high-reflection mirror to deliver the sharpest images and improve scanning speed.
  • Professional software
    As well as Epson Scan, the V850 Pro comes with SilverFast SE Plus 8 and i1 Scanner software for advanced scanning features to help give you the professional-looking results you demand.
Epson Perfection V850 Pro - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
White LED
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
Interpolated Resolution
12800 dpi x 12800 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, film
Document Feeder Type
Automatic
AC 230V (50 - 60 Hz)
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1
50.3 cm x 30.8 cm x 15.2 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
CCD
Bulb / Light Source Type
White LED
Scan Density Range
4.0D
Scanner Speed Details
12 sec/scan - draft - A4 , 15 sec/scan - best - A4 , 6 sec/scan - preview - A4 , 59 sec/scan - film (negatives) - 35mm - 4800 dpi , 32 sec/scan - film (negatives) - 35mm - 2400 dpi , 66 sec/scan - film (positives) - 35mm - 4800 dpi , 37 sec/scan - film (positives) - 35mm - 2400 dpi
Scanner Features
Digital ICE Technology, EPSON ReadyScan LED Technology, Backlight Correction, Grain Correction
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper, film
Automatic
Interfaces Details
USB 2.0 - Type B
8 film holders
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
23 Watt
Power Consumption Stand by
12 Watt
Power Consumption Sleep
1.5 Watt
Software Included
Drivers & Utilities, EPSON Scan, EPSON Event Manager, EPSON Copy Utility, LaserSoft Imaging SilverFast SE 8, X-Rite i1 Scanner
50.3 cm
30.8 cm
15.2 cm
6.6 kg
Limited warranty - 1 year - carry-in
5 °C
35 °C
10 - 80%
B5SK Epson CoverPlus 3 Years onsite Warranty In Stock £60.60
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: £750 - £1000
