Ultra-compact and tidy
The V39's power and connectivity is handled via a single Micro USB to reduce cable clutter and keep your workspace tidy. The device also has a built-in stand for flexible scanning to suit your desk space.
Fast, high-quality results
Thanks to Epson's ReadyScan LED Technology, you can start scanning instantly - no warm-up time is required. Make sure that even your old photos look their best with Epson Easy Photo Fix software, which improves the quality of your scans by removing dust, restoring faded colours and correcting backlight. Even your scanned documents will look great as the V39 comes with a range of enhancement features, enabling you to improve text sharpness and remove unwanted 'bleed-through' from double-sided documents.
Convenient
To make scanning quick and easy, the V39 has four one-touch buttons so you can scan, copy, share and turn your photos and documents into multi-page searchable PDFs at the push of a button. For added versatility, a fully-detachable lid makes scanning of thick books, photo albums and other bound items possible. Thanks to clever software the V39 can even handle larger photos and documents - simply scan the large item in A4 sections and then seamlessly join the sections back together to create the whole image . Scan directly to cloud storage services such as SugarSync and Evernote and easily share your photos with family and friends by scanning straight to Facebook and Picasa.
Efficient power usage
With a power consumption of only 2.5 W during operation, this scanner is designed for energy efficiency, making it an eco-friendly choice for your scanning needs. -
High-resolution scanning
Boasting a maximum horizontal and vertical optical resolution of 4800 DPI, the Epson Perfection V39 delivers sharp, detailed images from your documents and photos. -
Versatile document handling
Equipped to handle plain paper and featuring a manual document feeder, this scanner accommodates a variety of scanning tasks, ensuring flexibility in your projects.
- Epson Perfection V39 - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- White LED
- Additional Functions
- Scan to cloud
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 4800 dpi x 4800 dpi
- Interpolated Resolution
- 6400 dpi x 6400 dpi
- Max Document Size
- 216 mm x 297 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Manual
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x, Windows 8.1, Apple MacOS X 10.9.x
- 24.9 cm x 36.4 cm x 3.9 cm
- 1.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- Scan to cloud
- A4 (210 x 297 mm)
Scanner
- Input Type
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- Bulb / Light Source Type
- White LED
- Control Panel Buttons Functions
- Copy, start, send to, PDF
- Scanner Speed Details
- 10 sec/scan - black & white - A4 - 300 dpi , 10 sec/scan - colour - A4 - 300 dpi , 12 sec/scan - black & white - A4 - 600 dpi , 29 sec/scan - colour - A4 - 600 dpi
- Scanner Features
- Backlight Correction, Text Enhancement, RGB Color Dropout, A2 stitching
Media Handling
- Max Document Size
- 216 mm x 297 mm
- Plain paper
- Manual
- Interfaces Details
- USB 2.0 - Type AB
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Consumption Operational (Standby)
- 2.5 Watt
- Power Consumption Stand by
- 1.1 Watt
- Software Included
- EPSON Scan, ArcSoft Scan-n-Stitch Deluxe, EPSON Copy Utility, EPSON Document Capture Pro, EPSON Easy Photo Scan, EPSON Document Capture
- OS Required
- 24.9 cm
- 36.4 cm
- 3.9 cm
- 1.5 kg
- Limited warranty - 1 year - carry-in
- 10 °C
- 35 °C
- 20 - 80%
Epson CoverPlus 3 Years onsite Warranty | In Stock | £19.01 |
