Epson Perfection V330 A4 Flatbed
Epson Perfection V330 Photo
Quicklinx: 76JGWS00 Mfr#: B11B200312
High performance, low energy
Begin scanning photos and documents straight away with virtually no warm-up time. Then experience great image quality thanks to Epson ReadyScan LED technology. You can also reduce your energy bill as the Epson Perfection V330 Photo has a low power consumption.
Powerful software
Larger photographs can be seamlessly connected to form a panoramic image. With stitching software to seamlessly scan and join images bigger than A4 and a built-in transparency unit to scan slides and film, this is a scanner that delivers superb results.
Remove and restore
Your photos, slides and film will be returned to a near-original state: restore colour, remove dust particles and correct backlight with Epson Easy Photo Fix software.
Flexible design
Scan in either portrait or landscape. You can even scan books or 3D objects thanks to the extendable hinge design.
Easy to use
Scanning to multi-page and searchable PDFs is simple, and you can also scan straight to email with a one-touch button.
  • ADVANCED SCANNING
    Capture more detail with this 4,800 dpi CCD scanner that has the superior quality you would expect from an Epson Perfection scanner.
Epson Perfection V330 Photo - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
White LED
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
16-bit (64K grey levels) / 48-bit colour
Optical Resolution
4800 dpi x 9600 dpi
Interpolated Resolution
12800 dpi x 12800 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Transparencies, plain paper, film
Document Feeder Type
Manual
AC 120/230 V (50 - 60 Hz)
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
Microsoft Certification
Compatible with Windows 7
43 cm x 28 cm x 6.7 cm
2.8 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
4800 dpi x 9600 dpi
CCD
Bulb / Light Source Type
White LED
Scan Density Range
3.2D
Control Panel Buttons Functions
Copy, start, Scan-to-Email, Scan-to-PDF
Scanner Speed Details
11 sec/scan - preview - A4 , 16 sec/scan - colour - A4 - 300 dpi , 37 sec/scan - colour - A4 - 600 dpi , 16 sec/scan - black & white - A4 - 300 dpi , 30 sec/scan - black & white - A4 - 600 dpi , 21 sec/scan - film (negatives) - preview , 52 sec/scan - film (negatives) - 35mm - 2400 dpi , 72 sec/scan - film (negatives) - 35mm - 3200 dpi , 85 sec/scan - film (negatives) - 35mm - 4800 dpi , 110 sec/scan - film (positives) - preview , 42 sec/scan - film (positives) - 35mm - 2400 dpi , 57 sec/scan - film (positives) - 35mm - 3200 dpi , 85 sec/scan - film (positives) - 35mm - 4800 dpi
Scanner Features
Digital ICE Technology, EPSON ReadyScan LED Technology
Media Handling
Max Document Size
216 mm x 297 mm
Manual
Interfaces Details
USB 2.0 - Type B
Film holder
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
12 Watt (3.7 Watt)
Software Included
EPSON Scan, ArcSoft Scan-n-Stitch Deluxe, EPSON Event Manager, EPSON Copy Utility, ArcSoft MediaImpression 2, ABBYY FineReader 9.0 Sprint Plus, ABBYY FineReader 8.0 Sprint Plus for MAC
43 cm
28 cm
6.7 cm
2.8 kg
Limited warranty - 1 year
5 °C
35 °C
10 - 80%
