Epson PE Matte Label For Die-Cut 203x152mm
Quicklinx: C3V9WS00 Mfr#: C33S045553
White matte inkjet synthetic labels compliant with the BS 5609 standard for GHS chemical labels. Resistant to water, heat and most chemicals, these PE-based labels can be used for smudge-proof, accurate and scannable full colour printing. A water-borne acrylic adhesive delivers excellent adhesion and UV-stability for permanent, reliable, on-demand results.
Suggested applications
• Ghschemical labels
• Pharmaceutical labels
• Laboratory labels.
  • PE matte label
    White, matte, synthetic, inkjet labels compliant with the BS 5609 standard for GHS chemical labels.
Epson PE - die cut fanfold labels with sprockets - matte - 1000 sheet(s) - 203 x 152 mm
Die cut fanfold labels with sprockets
Surface Finish
Matte
Adhesive Type
Adhesive
Media Size
203 x 152 mm
Included Qty
1000 sheet(s)
Compatible with
Epson GP-C831, GP-M831
Media
Media Type
Surface Finish
Matte
Adhesive Type
Adhesive
Media Sizes
203 x 152 mm
Included Qty
1000 sheet(s)
Heat-resistant, water-resistant, smudge-resistant, chemicals-resistant
Compatible with
