White matte inkjet synthetic labels compliant with the BS 5609 standard for GHS chemical labels. Resistant to water, heat and most chemicals, these PE-based labels can be used for smudge-proof, accurate and scannable full colour printing. A water-borne acrylic adhesive delivers excellent adhesion and UV-stability for permanent, reliable, on-demand results.
Suggested applications
• Ghschemical labels
• Pharmaceutical labels
• Laboratory labels.
PE matte label
White, matte, synthetic, inkjet labels compliant with the BS 5609 standard for GHS chemical labels.
- Epson PE - die cut fanfold labels with sprockets - matte - 1000 sheet(s) - 203 x 152 mm
- Product Type
- Die cut fanfold labels with sprockets
- Surface Finish
- Matte
- Adhesive Type
- Adhesive
- Media Size
- 203 x 152 mm
- Included Qty
- 1000 sheet(s)
- Compatible with
- Epson GP-C831, GP-M831
Media
- Media Type
- Surface Finish
- Matte
- Adhesive Type
- Adhesive
- Media Sizes
- 203 x 152 mm
- Included Qty
- 1000 sheet(s)
- Heat-resistant, water-resistant, smudge-resistant, chemicals-resistant
- Compatible with
