Epson-compatible scanners can be shared across departments and workgroups, thanks to the Epson Network Interface Panel with Push Scan features.
Effortless compatibility
Designed to seamlessly integrate with both Mac and PC environments, ensuring a smooth connection without the hassle of additional drivers or software. -
High-speed connectivity
Features an Ethernet 10Base-T/100Base-TX interface, providing reliable and fast data transfer rates of up to 1000 Mbps, making large file transfers and network communication more efficient. -
Versatile networking
Supports a wide range of networking standards including Ethernet, Fast Ethernet, and Gigabit Ethernet, allowing for flexible network configurations and enhanced scalability. -
Easy installation
Comes with a mounting kit included, facilitating straightforward setup and integration into existing network infrastructures without the need for professional assistance. -
Robust design
The external form factor of the scanner server is designed to withstand the demands of busy work environments, ensuring durability and long-term reliability.
- Epson Network Scan Module - scanner server - 10/100 Ethernet
- Scanner server
- Form Factor
- External
- Ports
- 10/100 Ethernet
- 15.9 cm x 8.3 cm x 7 cm
- 318 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1000 Mbps
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x
- 1-year warranty
- Designed For
- Epson DS-6500, DS-7500; WorkForce DS-50000, DS-50000N, DS-5500, DS-5500N, DS-60000, DS-60000N, DS-6500, DS-6500N, DS-70000, DS-70000N, DS-7500, DS-7500N
- Scanner server
- Form Factor
- External
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1000 Mbps
- 1 x 100Base-TX - RJ-45
- Mounting Kit
- Included
- OS Required
- 15.9 cm
- 8.3 cm
- 7 cm
- 318 g
- Limited warranty - 1 year
- Designed For
- Epson DS-6500, DS-7500 , Epson WorkForce DS-50000, DS-50000N, DS-5500, DS-5500N, DS-60000, DS-60000N, DS-6500, DS-6500N, DS-70000, DS-70000N, DS-7500, DS-7500N
