Epson Network Interface Panel Workforce DS-5500N
Quicklinx: BYHPWS00 Mfr#: B12B808411
Epson-compatible scanners can be shared across departments and workgroups, thanks to the Epson Network Interface Panel with Push Scan features.
  • Effortless compatibility
    Designed to seamlessly integrate with both Mac and PC environments, ensuring a smooth connection without the hassle of additional drivers or software.
  • High-speed connectivity
    Features an Ethernet 10Base-T/100Base-TX interface, providing reliable and fast data transfer rates of up to 1000 Mbps, making large file transfers and network communication more efficient.
  • Versatile networking
    Supports a wide range of networking standards including Ethernet, Fast Ethernet, and Gigabit Ethernet, allowing for flexible network configurations and enhanced scalability.
  • Easy installation
    Comes with a mounting kit included, facilitating straightforward setup and integration into existing network infrastructures without the need for professional assistance.
  • Robust design
    The external form factor of the scanner server is designed to withstand the demands of busy work environments, ensuring durability and long-term reliability.
Epson Network Scan Module - scanner server - 10/100 Ethernet
Scanner server
External
Ports
10/100 Ethernet
15.9 cm x 8.3 cm x 7 cm
318 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1000 Mbps
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x
1-year warranty
Epson DS-6500, DS-7500; WorkForce DS-50000, DS-50000N, DS-5500, DS-5500N, DS-60000, DS-60000N, DS-6500, DS-6500N, DS-70000, DS-70000N, DS-7500, DS-7500N
Scanner server
External
Ports
10/100 Ethernet
Wired
Cabling Type
Data Transfer Rate
1000 Mbps
1 x 100Base-TX - RJ-45
Mounting Kit
Included
15.9 cm
8.3 cm
7 cm
318 g
Limited warranty - 1 year
Epson DS-6500, DS-7500 , Epson WorkForce DS-50000, DS-50000N, DS-5500, DS-5500N, DS-60000, DS-60000N, DS-6500, DS-6500N, DS-70000, DS-70000N, DS-7500, DS-7500N
