Epson LX-350 Mono Dot Matrix Printer
Quicklinx: 8KKCWS00 Mfr#: C11CC24032
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Dot-matrix
19 left in stock
£203.38 ex VAT
£244.05 inc VAT
A very economical printer to run, the LX-350 helps save money with its high ribbon yield of 4 million characters and its low power consumption. Using just 1.1W in sleep mode and 27W when powered on, the LX-350 is qualified by ENERGY STAR for its excellent energy efficiency.
Easy to integrate, the LX-350 has Parallel, Serial and USB interfaces as standard, and will fit neatly onto desks thanks to its compact design and cable management system.
  • High reliability
    MTBF of 10,000 operating hours.
  • Power-efficient
    1.1 W on standby, 27 W powered on.
  • Economical
    Ribbon yield of 4 m characters.
  • Easy integration
    Parallel, serial and USB interfaces.
  • Compact design
    Fits neatly onto desks.
Epson LX 350 - printer - B/W - dot-matrix
Printer Type
Personal printer - dot-matrix - 9 pin - B/W
4.1 kg
Print Speed
Up to 347 char/sec - high speed draft , Up to 357 char/sec - high speed draft , Up to 260 char/sec - draft , Up to 312 char/sec - draft , Up to 65 char/sec - near letter , Up to 78 char/sec - near letter
Parallel, USB, serial
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P
Media Type
Envelopes, labels, plain paper, continuous forms
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
34.8 cm x 27.5 cm x 15.4 cm
Printer Type
Personal printer - dot-matrix - 9 pin - monochrome
Printer
Print Speed
Up to 347 char/sec - high speed draft - 10 cpi , Up to 357 char/sec - high speed draft - 12 cpi , Up to 260 char/sec - draft - 10 cpi , Up to 312 char/sec - draft - 12 cpi , Up to 65 char/sec - near letter - 10 cpi , Up to 78 char/sec - near letter - 12 cpi
Wired
Language Simulation
EPSON ESC/P
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x serial - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
Consumables Included
1 x ribbon (black) - up to 4 million characters
MTBF
10,000 hour(s)
Power supply - internal
27 Watt
Power Consumption Stand by / Sleep
1.1 Watt
Software Included
EPSON Status Monitor
Environmental Standards
ENERGY STAR
Limited warranty - 2 years - carry-in
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
53 dBA
34.8 cm
27.5 cm
15.4 cm
4.1 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: [N/A]
Brand: Epson
Stock Status: While stocks last
Stock Status: Clearance
