There is a new High-Speed Draft mode that delivers an astonishing 337 characters per second! An even bigger surprise is that the LX-300+II is still one the quietest printers in its class.
It out-performs its predecessor with a new bottom-feed paper path that's ideal for handling complex, multi-page forms. Even on multi-page forms that are five layers thick, the LX-300+II delivers crisp, clean printouts to the very last page.
Speed
There is a new High-Speed Draft mode that delivers an astonishing 337 characters per second! An even bigger surprise is that the LX-300+II is still one the quietest printers in its class. -
Paper handling
- Epson LX 300+II Colour - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 9 pin - B/W
- 4.4 kg
- Print Speed
- Up to 300 char/sec - high speed draft , Up to 225 char/sec - draft , Up to 56 char/sec - near letter , Up to 270 char/sec - draft , Up to 67 char/sec - near letter , Up to 337 char/sec - high speed draft
- Interface
- Parallel, USB, serial
- RAM Installed (Max)
- 64 KB
- Language Simulation
- EPSON ESC/P, IBM 2380 Plus
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
- Media Type
- Envelopes, labels, plain paper, continuous forms
- System Requirements
- Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP
- 1-year warranty
- 36.6 cm x 27.5 cm x 15.9 cm
- Printer Type
- Personal printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 300 char/sec - high speed draft - 10 cpi , Up to 225 char/sec - draft - 10 cpi , Up to 56 char/sec - near letter - 10 cpi , Up to 270 char/sec - draft - 12 cpi , Up to 67 char/sec - near letter - 12 cpi , Up to 337 char/sec - high speed draft - 12 cpi
- Connectivity Technology
- Wired
- Interface
- Fonts Included
- 8 x barcode
- Barcodes
RAM
- 64 KB
Media Handling
- Media Type
- Media Sizes
- A4 (210 x 297 mm)
- Max Sheets in Multi-Part Form
- 5
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
- Included Accessories
- Colour upgrade kit
- Consumables Included
- 1 x ribbon (black) - up to 3 million characters
- MTBF
- 6,000 hour(s)
- Power Device
- Power supply - internal
- 23 Watt
- Software Included
- EPSON Status Monitor
- OS Required
- Limited warranty - 1 year - carry-in
- 5 °C
- 35 °C
- 10 - 80%
- Sound Emission (Operating)
- 49 dBA
- 36.6 cm
- 27.5 cm
- 15.9 cm
- 4.4 kg
