Epson LX-300+ II
Epson LX-300+ II
Quicklinx: 49TDWS00 Mfr#: C11C640051
Reliable, low cost dot matrix printer. The Epson LX-300+II 9 pin dot matrix printer is fast, durable and ultra reliable. Printing A4 sheets at 337 cps, it's very efficient and extremely cost-effective to run. Compact and easy to use, ideal for front and back office use, where space is at a premium and reliable light duty printing is required.
Perfect for PoS applications or transaction printing from measurement and control systems, it's simple to use, has 8 built-in bar code fonts and prints up to 5 part forms. An upgrade kit is available with colour fabric ribbons for enhanced functionality. Versatile paper management, with the ability to handle both cut sheet and continuous stationery, its flexible paper management allows paper insertion from the top, rear and bottom.
Epson LX 300+II - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - B/W
4.4 kg
Max Media Size
JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Max Media Size (Custom)
257 mm x 559 mm
Print Speed
Up to 337 char/sec - fast draft , Up to 300 char/sec - fast draft , Up to 270 char/sec - draft , Up to 56 char/sec - letter , Up to 67 char/sec - letter
Parallel, USB, serial
RAM Installed (Max)
64 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, labels, plain paper, continuous forms
Microsoft Windows NT 4.0, Microsoft Windows 95/98, Microsoft Windows 3.1, Microsoft Windows 2000, Microsoft Windows NT 3.5
Microsoft Certification
Works with Windows Vista
1-year warranty
36.6 cm x 27.5 cm x 15.9 cm
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
Print Speed
Up to 337 char/sec - fast draft - 12 cpi , Up to 300 char/sec - fast draft - 10 cpi , Up to 270 char/sec - draft - 12 cpi , Up to 56 char/sec - letter - 10 cpi , Up to 67 char/sec - letter - 12 cpi
Wired
Fonts Included
8 x barcode
Barcodes
RAM
RAM Installed (Max)
64 KB
Media Handling
Media Type
Max Media Size
257 mm x 559 mm
Media Sizes
Legal (216 x 356 mm), 254 x 559 mm, Roll (21.6 cm), 101.6 x 101.6 mm, JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Media Weight
52 g/m² - 82 g/m²
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x serial , 1 x USB
MTBF
6,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Frequency Required
50/60 Hz
23 Watt
Limited warranty - 1 year
Sound Emission (Operating)
49 dBA
36.6 cm
27.5 cm
15.9 cm
4.4 kg
Resources
The following resources are available for the Epson LX-300+ II
