Epson LQ350 Dot Matrix Printer
Quicklinx: 8NVNWS00 Mfr#: C11CC25002
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Dot-matrix
£209.77 ex VAT
£251.72 inc VAT
A very economical printer to run, the LQ-350 helps save money with its high ribbon yield of 2.5 million characters and its low power consumption. Using just 1.3W in sleep mode and 23W when powered on, the LQ-350 is qualified by ENERGY STAR for its excellent energy efficiency.
Easy to integrate, the LQ-350 has Parallel, Serial and USB interfaces as standard, and will fit neatly onto desks thanks to its compact design and cable management system.
  • High reliability
    MTBF of 10,000 operating hours.
  • Power-efficient
    1.3 W on standby, 22 W powered on.
  • Economical
    Ribbon yield of 2.5 m characters.
  • Easy integration
    Parallel, serial and USB interfaces.
  • Compact design
    Fits neatly onto desks.
Epson LQ 350 - printer - B/W - dot-matrix
Printer Type
Personal printer - dot-matrix - 24 pin - B/W
4.1 kg
Print Speed
Up to 347 char/sec - max speed , Up to 260 char/sec - draft , Up to 86 char/sec - laser quality
Parallel, USB 2.0, USB host
RAM Installed (Max)
128 KB integrated
Language Simulation
EPSON ESC/P 2, IBM 2390 Plus
Media Type
Envelopes, labels, plain paper, continuous forms
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
34.8 cm x 27.5 cm x 15.4 cm
Printer Type
Personal printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 347 char/sec - max speed - 10 cpi , Up to 260 char/sec - draft - 10 cpi , Up to 86 char/sec - laser quality
Wired
Language Simulation
RAM
RAM Installed (Max)
128 KB
Technology / Form Factor
Integrated
Media Handling
Media Type
Media Feeders
1 x manual
1 x parallel , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ribbon
MTBF
10,000 hours
Power supply - internal
22 Watt
Software Included
Drivers & Utilities
Limited warranty - 2 years - carry-in
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
53 dBA
34.8 cm
27.5 cm
15.4 cm
4.1 kg
8NVN Epson Black Ribbon Cartridge for LQ-350/300/+/+II In Stock £4.91
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: [N/A]
Brand: Epson
