Epson LQ 630 Mono Dot-Matrix Printer
Quicklinx: 65NRWS00 Mfr#: C11C480019A1
Compact, robust design for counter top use. The Epson LQ-630 24 pin dot matrix printer has a notably small footprint - perfect for restricted space environments in businesses such as retailers, surgeries, ticket offices and trade counters. Low cost, high quality flatbed dot matrix printer.
Fast and ultra reliable, the Epson LQ-630 prints at 360 cps and is extremely economical to run. The straight, flat front feed paper path is perfect for a range of applications including small cut sheet, labels and up to 5 part stationery.
  • Compact, robust design for counter top use
  • Low cost, high quality flatbed dot matrix printer
  • Ergonomic flatbed with front paper feed
Epson LQ 630 - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
3.5 kg
Max Media Size
JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Print Speed
Up to 300 char/sec - fast draft , Up to 360 char/sec - fast draft , Up to 225 char/sec - draft , Up to 270 char/sec - draft , Up to 337 char/sec - draft , Up to 192 char/sec - draft , Up to 225 char/sec - draft , Up to 79 char/sec - best , Up to 94 char/sec - best , Up to 118 char/sec - best , Up to 135 char/sec - best , Up to 158 char/sec - best
Parallel, USB
RAM Installed (Max)
32 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Labels, plain paper
Microsoft Windows 95, Microsoft Windows NT 4.0, Microsoft Windows XP, Microsoft Windows 98/ME/2000
Microsoft Certification
Works with Windows Vista
1-year warranty
38.6 cm x 30.6 cm x 18.5 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 300 char/sec - fast draft - 10 cpi , Up to 360 char/sec - fast draft - 12 cpi , Up to 225 char/sec - draft - 10 cpi , Up to 270 char/sec - draft - 12 cpi , Up to 337 char/sec - draft - 15 cpi , Up to 192 char/sec - draft - 17 cpi , Up to 225 char/sec - draft - 20 cpi , Up to 79 char/sec - best - 10 cpi , Up to 94 char/sec - best - 12 cpi , Up to 118 char/sec - best - 15 cpi , Up to 135 char/sec - best - 17 cpi , Up to 158 char/sec - best - 20 cpi
Wired
Parallel, USB
Columns
80
Barcodes
RAM
RAM Installed (Max)
32 KB
Media Handling
Media Type
Labels, plain paper
Max Media Size
Media Sizes
JIS B4 (257 x 364 mm), 70 x 90 mm, continuous paper 101.6 mm - 254 mm (width)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
MTBF
6,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Frequency Required
50/60 Hz
20 Watt
Power Consumption Stand by / Sleep
5 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Operating)
57 dB
38.6 cm
30.6 cm
18.5 cm
3.5 kg
