Epson LQ 630 Dot Matrix Network Printer
Quicklinx: DDCPWS00 Mfr#: C11C480141A0
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Continuous paper 101.6 mm - 254 mm (width), JIS B4 (257 x 364 mm)
£425.79 ex VAT
£510.94 inc VAT
LQ-630 is a small and reliable printer especially for counter application. With its small design with 80 columns, LQ-630 fits perfectly in environments where space is rather limited. The ejection of both, continuous paper and cut sheets at front side enables easy handling of the print outs only at the front side of the printer. Due to the printer's flatbed technology, LQ-630 can print even smallest cut sheet forms and stickers down to 9 cm x 7 cm. LQ-630 can ideally be used with retail stores, banks, post offices, doctors' surgeries, ticket shops, cinemas, pizza services. Moreover the printer is perfect for label and protocol printing with trade industrial firms.
  • Compact, robust design for counter top use
    The Epson LQ-630 24 pin dot matrix printer has a notably small footprint - perfect for restricted space environments in businesses such as retailers, surgeries, ticket offices and trade counters.
  • Low cost, high quality flatbed dot matrix printer
    Fast and ultra reliable, the Epson LQ-630 prints at 360 cps and is extremely economical to run.
  • Ergonomic flatbed with front paper feed
    The straight, flat front feed paper path is perfect for a range of applications including small cut sheet, labels and up to 5 part stationery.
Epson LQ 630 - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
3.5 kg
Max Media Size
JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Print Speed
Up to 300 char/sec - fast draft , Up to 360 char/sec - fast draft , Up to 225 char/sec - draft , Up to 79 char/sec - best
Max Resolution (B&W)
360 x 180 dpi
Parallel, USB 2.0
RAM Installed (Max)
32 KB
Language Simulation
EPSON ESC/P 2, IBM PPDS
Media Type
Labels, plain paper, continuous forms
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Windows 8
1-year warranty
38.6 cm x 30.6 cm x 18.5 cm
Printer Type
Printer
Print Speed
Up to 300 char/sec - fast draft - 10 cpi , Up to 360 char/sec - fast draft - 12 cpi , Up to 225 char/sec - draft - 10 cpi , Up to 79 char/sec - best - 10 cpi
Wired
Parallel, USB 2.0
360 x 180 dpi
Language Simulation
RAM
RAM Installed (Max)
32 KB
Media Handling
Media Type
Max Media Size
Media Sizes
1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
MTBF
10,000 hour(s)
20 Watt
Power Consumption Stand by
4.8 Watt
Software Included
Drivers & Utilities, EPSON Status Monitor
Limited warranty - 1 year - carry-in
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
57 dB
38.6 cm
30.6 cm
18.5 cm
3.5 kg
Type: Printer
Max Paper Size: JIS B4 (257 x 364 mm)
Brand: Epson
Price Range Ex VAT: 300 - 500
