Epson LQ 300+II Colour Dot Matrix Printer Monochrome
Quicklinx: CHFZWS00 Mfr#: C11C638001A5
Works hard
It might be compact, but this 24-pin, 80-column A4 printer gives a great performance. It's also very reliable and cost-effective to run.
Easy to use
The Epson LQ-300+II printer will fit right into your business. It prints up to 4 part forms and has 8 built-in barcode fonts to make your life even easier.
Paper handling
Choose from standard or optional paper handling from top, rear and bottom and print on cut sheet and continuous media.
  • Works hard
  • Easy to use
  • Paper handling
Epson LQ 300+II Colour - printer - B/W - dot-matrix
Printer Type
Personal printer - dot-matrix - 24 pin - B/W
4.4 kg
Print Speed
Up to 300 char/sec - high speed draft , Up to 225 char/sec - draft , Up to 75 char/sec - letter , Up to 270 char/sec - draft , Up to 90 char/sec - letter
Parallel, USB, serial
RAM Installed (Max)
64 KB
Language Simulation
EPSON ESC/P 2, IBM 2390 Plus
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, labels, plain paper, continuous forms
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP
1-year warranty
36.6 cm x 27.5 cm x 15.9 cm
Printer Type
Personal printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 300 char/sec - high speed draft - 10 cpi , Up to 225 char/sec - draft - 10 cpi , Up to 75 char/sec - letter - 10 cpi , Up to 270 char/sec - draft - 12 cpi , Up to 90 char/sec - letter - 12 cpi
Wired
Language Simulation
Fonts Included
8 x barcode
Barcodes
RAM
RAM Installed (Max)
64 KB
Media Handling
Media Type
Media Sizes
A4 (210 x 297 mm)
Max Sheets in Multi-Part Form
4
1 x parallel - 36 PIN Centronics , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
Consumables Included
1 x ribbon (black) - up to 2 million characters
MTBF
6,000 hour(s)
Power supply - internal
20 Watt
Software Included
EPSON Status Monitor
Limited warranty - 1 year
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
49 dBA
36.6 cm
27.5 cm
15.9 cm
4.4 kg
