Epson LQ 2190 Mono Dot-Matrix Printer
Quicklinx: 7CXRWS00 Mfr#: C11CA92001A0
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Dot-matrix
£895.35 ex VAT
£1,074.42 inc VAT
"Reliability and speed. This 24-pin wide carriage printer takes care of big print jobs without a fuss. You can rely on high quality results on a wide range of paper types while the impressive 576 cps (at 12 cpi) print speed is perfect for large volume tasks. This robust device is very dependable and has a print head life of 400 million strokes per wire, plus a meant time between failure of 20,000 power-on hours.
Flexibility. Choice of front, top, bottom and rear paper paths gives you even more control over desk space management. And the addition of a USB interface means more flexibility in connectivity.
Longer ribbon life. With a ribbon life of around 15 million characters, the ribbon replacement cycles are longer, which brings down running costs and maintenance time."
  • Reliability
    With MTBF (mean time between failure) of 20,000 power-on hours and a print head life of 400 million strokes per wire, this extremely robust printer is suitable for medium and large print volumes. Both features guarantee uninterrupted operation and less maintenance, in turn enhancing your productivity and reducing your total cost of ownership.
  • Speed
    Its high print speed of up to 480 cps (10 cpi) makes it an ideal solution for high volume applications. For those who demand even higher productivity especially for complex fonts like Arabic, the unique Epson Print Speed Enhancer accelerates the print speed even further.
  • Flexibility
    Flexible paper management allows insertion at the front, rear and bottom and dual tractor units allow you to load two sizes of paper at the same time, ready for use. The ability to print on 6-part stationery is useful for multipart forms. With the addition of USB interface, the LQ-2190 also provides flexible stand-alone connectivity.
  • High ribbon yield
    At 15 million characters per ribbon, the LQ-2190 also offers a very long ribbon life. The benefits are long ribbon replacement intervals, low running costs and lower total cost of ownership.
Epson LQ 2190 - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
13 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Print Speed
Up to 480 char/sec - fast draft , Up to 576 char/sec - fast draft , Up to 360 char/sec - draft , Up to 432 char/sec - draft , Up to 120 char/sec - laser quality , Up to 144 char/sec - laser quality
Max Resolution (B&W)
10 cpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P 2, IBM PPDS
Media Type
Envelopes, labels, plain paper, continuous forms, cards
AC 240 V
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
1-year warranty
63.9 cm x 40.2 cm x 25.6 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 480 char/sec - fast draft - 10 cpi , Up to 576 char/sec - fast draft - 12 cpi , Up to 360 char/sec - draft - 10 cpi , Up to 432 char/sec - draft - 12 cpi , Up to 120 char/sec - laser quality - 10 cpi , Up to 144 char/sec - laser quality - 12 cpi
Wired
Parallel, USB
10 cpi
Language Simulation
Fonts Included
10 x bitmapped , 4 x scalable , 8 x barcode
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Media Sizes
A3 (297 x 420 mm)
Media Feeders
1 x manual
Max Sheets in Multi-Part Form
6
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
MTBF
20,000 hour(s)
Power supply - internal
AC 240 V
46 Watt
Power Consumption Stand by / Sleep
3 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - carry-in
Sound Emission (Operating)
54 dB
63.9 cm
40.2 cm
25.6 cm
13 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: A3 (297 x 420 mm)
Brand: Epson
Price Range Ex VAT: 750 - 1000
