The Epson LQ-590 and Epson LQ-2090 bring exceptional performance to the 24pin segment. In addition to high speed printing up to 529 characters per second, they are extremely compact, robust and reliable. This is perfect for the relentless everyday demands of busy environments like doctors´ surgeries, banks, travel agencies and freight forwarders. Versatile paper management also comes as standard, for fast, flexible printing of orders and invoices, labels, system event logs, cheques and barcodes.
- Epson LQ 2090 - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - B/W
- 9.5 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Print Speed
- Up to 529 char/sec - fast draft , Up to 440 char/sec - fast draft , Up to 396 char/sec - draft , Up to 330 char/sec - draft , Up to 132 char/sec - letter , Up to 110 char/sec - letter
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 61.3 cm x 37.5 cm x 17.2 cm
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
- Print Speed
- Up to 529 char/sec - fast draft - 12 cpi , Up to 440 char/sec - fast draft - 10 cpi , Up to 396 char/sec - draft - 12 cpi , Up to 330 char/sec - draft - 10 cpi , Up to 132 char/sec - letter - 12 cpi , Up to 110 char/sec - letter - 10 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- Fonts Included
- 10 x bitmapped , 4 x scalable , 8 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Media Sizes
- A3 (297 x 420 mm)
- Max Sheets in Multi-Part Form
- 5
- Connections
- 1 x parallel , 1 x USB
- MTBF
- 20,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Limited warranty - 1 year
- Sound Emission (Operating)
- 50 dBA
- 61.3 cm
- 37.5 cm
- 17.2 cm
- 9.5 kg
Epson LQ2090 Printer Ribbon | In Stock | £18.94 |
